Any axle back npp that add power and drop weight?
And sound as good as the factory suitcase? (No drone/not unbearably loud)
I'm guessing not more then a gain of 5hp or so, but 10-20lbs less weight??? |
I believe I saw someone a while back weigh the stock unit vs Corsa extreme and the Corsa was 20lbs lighter. It will be louder tho. Doubt you will find a system as quiet than the stock unit.
The only one I've ever seen that actually adds power is the one WeaponX added to their car... http://i10.photobucket.com/albums/a1...psxhha0g3z.jpg
afe power is what i have not sure about weight but definately adds a bit of power
New Corsa NPP is nice and gets really quiet when valves are closed. Its a pretty penny though at average price of 1900.
AFE here as well, no dyno but it is certainly lighter. And louder, in a good way
This was my findings when I switched out my exhaust
To my surprise the awe setup only saves 3lbs over the factory setup. Just found this interesting so I figured I would share my findings. Awe touring cat back non resonated with performance link pipes: 76.2lbs Tips (4): 6.6lbs Muffler (2): 29.2lbs Mid pipes: 30.2lbs Link pipes: 5.6lbs Clamps: 4.6lbs Factory NPP cat back: 79.2lbs Muffler: 42lbs Mid pipes & secondary cats: 37.2lbs |
3 Attachment(s)
I just had the Borla S-Type Axle Back with the Carbon Fiber Tips installed a couple weeks ago. I love the look of the CF tips and I think it sounds a lot better than the factory suitcase! I am not sure if there is any gain in power? In the spring I will be doing Header's and cat delete and some bolt-ons, but for now it has a deeper sound to it especially when on the gas!! :headbang:
Add: Where’d you get the CF plate frame? I have one on the rear now, but I need one for the front since this one is squared & looks like ass with the radius’d front plate bracket. |
Boy that weapon x setup has got one goofy lookin muffler...
I heard if you get a black tipped exhaust it boost the hp by 15. Now imagine if you made it red! MAXIMUM OVERDRIVE
I got the CF plate frame off of Amazon :cool: |
here is the linky: https://www.amazon.com/License-Alumi...dDbGljaz10cnVl |
