Boost Limit
What's everyone running on the stock turbo for boost limits?
Trying to really sit down with HP Tuners and learn the 2.0s limits / how to do things |
Mines only turned up 1.5/2 @ 37.5 commanded. Factory is 35.44
You will start to loose power from the extra heat after 25/26psi. I know I did anyway, and you could see the difference in IAT's instantly. |
Anyone with a 2017 model having trouble increasing boost and having it hold? I have an ats and its a 17 model and it just seems that I cant get it to hold the spike of 23psi any longer than like a second or two before falling down to about 20 or 19
Your makin me wait like you did with the Sema grill aren't ya...:paddle: haha Quote:
Its not just your ATS. Its Camaro's, Malibus, Regals, CTS, Equinox, Traverse, Terrain, ECT ECT.... They all have the same crappy, plastic, leaky valve... You sir need a Jason@JacFab valve. It will hold more boost longer because it does not leak like the factory valve does.
Ya I know this, but here are other ltg cars I've seen where they can hold or carry about 22psi to redline and I'm falling to about 18-19 no matter what is changed in the tune. I guess all plastic valves are not created equal. lol |
You say he knows what boost is, yet no one in any context would ever refer to boost as including atmospheric. it's just not done. Tell your tuner that you're running 35psi and he will absolutely assume you're either uneducated or you're running some monster drag turbo on a fully built bonkers motor. And on a side note, that's the point of knowledge sharing - to help everyone use the correct vernacular and standards. |
Welp... I was just saying what the delivered boost was on my HPT Scanner.
Also, no I didn't know that actual boost was that reading - barometric or whatever. Im a noob at this stuff. I didn't try to prove anyone wrong. Oh well... |
