will a 305 35 20 throw off the computer?
Hello I had 305 35 20 and 275 45 20 on my 5th gen Camaro and was wandering if I could run them on then 6th gen or would it set off the computer? Thanks
No problems here but check clearances. Inside rear drivers side is a harness bulge front. 45s in front? I run 35s F/R.
There is a you-tube video that shows how to move the harness in the driver's side rear. It looks really simple. I am doing it tomorrow morning because my tires are HERE! If i have time i will take some pics and maybe do a writeup.
Bybcous... I think, is running 305-35-20 and 285-35-20 with zero issues on aftermarket wheels. That's what I ordered so I will know tomorrow. |
Just got mine on today. No rubbing yet. 305/35-20 in rear on 20x11 wheels. At 65 mph you will be off on your speedo by about 2mph. You will actually read 2mph higher than actual at 65 according to an online calculator. If you have a Garmin GPS that shows your speed you can verify this.
Sent from my SM-G920V using Tapatalk |
I just installed mine today too!
20" Front Size: 20x10.0 with 28mm 285-35 | Rear Size: 20x11.0 with 43mm 305-35 I moved the harness in the rear and no rubbing I needed a spacer in the front http://i197.photobucket.com/albums/a...psbjdlrebi.jpg |
Appears to be a 1/4" spacer. The tire store did it when I wasn't there. The guy has a 5th gen so I told him to drive it around. He said it wouldn't go without the spacer, like the brakes were on. Not sure if I could go with a thinner one. I can't get my fingers between the tire/strut. |
20x10 fronts BFG Comp 2 285/35-20 20x11 rears BFG Comp 2 305/35-20 Basically stock tire sizes from 2014 ZL1 (Tire Rack) |
So do we have to run spacers with the 228's. Mine are ordered and I was planning on running 275/35 front and 305/35 rear. thanks, Turbo8u |
I have 285/35 on front with no issues
I don't think it will rub if I lower it. Just a little bit more poke than I like. The back is perfect. |
