Rotor Wear Limits
Does anyone have wear limits the front and rear rotors for the SS with 4pot Brembos?
No measurements?
It should be written in the rotor. If I'm not mistaken it's 30mm
Well...I drive mine until the cracks are all the way to the outer edge. But this is only if you regularly abuse them at the track. |
Thanks. Yes, that is why I'm concerned, as I have been tracking the car. Very little pad wear, and each plate of the rotor is about 40mm, but wanted to know when to stop.... Before I don't.
I think you just run them until all the rotor iron has transferred to the pad. No? What do I know? I'm on set #3
In all seriousness, you will likely heat signature the rotors well in advance of the wear limits. I have a thread about it somewhere with pictures. Can't turn 'em at that point.
