11-27-2023, 09:11 AM | #15 |
Drives: 2023 Camaro 1SS Join Date: Apr 2014
The filter is a spin-on. Sometimes they're tight when they leave the factory, first oil change can be a bear to get the first filter off, which is why others are recommending a filter wrench (strap or cap).
Just remember to lube the seal on the new filter with some fresh oil, and once it stops spinning as you're tightening it, give it like 3/4 turn (there's usually even a pic on the Delco filters) to snug it up -- that's all it needs. Next time you change the oil, you should be able to unseat it by hand. Look up the torque spec for the oil pan drain bolt. People like to reef on those things and they just don't need to be that tight. The torque spec is plenty. $300 is steep for an oil change, but they're not taking advantage of "just you". That's their premium they're charging for the convenience of someone else working on your car. I agree it's ridiculous and the cost savings of doing it yourself is absolutely worth it, if you have the knowledge and tools to do it. |
11-27-2023, 01:05 PM | #16 | |
2020 Shadow Gray 2SS
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... BOTH are a lot of fun to operate... |
12-01-2023, 01:29 PM | #17 | |
Drives: 2023 Camaro ZL1 Join Date: Jan 2023
2023 Camaro ZL1 6MT Summit White
12-16-2023, 08:53 AM | #18 |
Drives: 2023 Sharkskin 2SS Join Date: Oct 2022
If you end up changing it yourself,
be sure to raise the vehicle from the proper lift points unless you are using ramps, then it don't matter. That Miami markup is a bit excessive... |
12-16-2023, 12:51 PM | #19 | |
Drives: 2022 Camaro 2SS Join Date: Apr 2023
The dealer that was trying to rip me off is AutoNation Chevrolet Doral, again for anyone in Miami. |
12-16-2023, 03:58 PM | #20 | |
12-16-2023, 05:26 PM | #21 |
12-16-2023, 05:31 PM | #22 |
Thread Tools | |
