06-29-2018, 10:50 AM | #1 |
Drives: 2011 Camaro LT Join Date: Mar 2015
Royal purple or Amsoil
What should I go with. I heard both were good just getting opinions. Also I just hit my 100k Im probably gonna service it my self because knowing the dealer I might have to chop an arm and leg off.
Radiator flush Power steering flush Brake flush Trans flush and new filter Differential flush Spark plugs---what brand?? I know AC delco is OE but maybe a different option. Any PVC fittings? Any small items I might need? |
06-29-2018, 11:27 AM | #2 |
Drives: 2010 Camaro SS 2SS Join Date: Jul 2017
No one could answer this question.
This is a very complex subject. However, ester based, long chain molecule refinement might provide the best protection by comparison. Having your oil analyzed can provide some insight as to the level of protection and deterioration of engine components and level of contaminates. Changing your oil more frequently has much more value than brand. |
06-29-2018, 11:32 AM | #3 |
Drives: 2011 Vistory Red 1LS Join Date: May 2018
Someone else may chime in but I have always heard it is a bad idea to flush an automatic transmission. It tends to loosen stuff up that ends up in places you don't want and causes failures. Just drain it and the diffy and replace the fluids.
I personally use Valvoline, but as long as the oil is a full synthetic and Dexos rated you should be alright.
The Original Farm Rat
2011 1LS M6 Victory Red Sold 1967 Coupe Green and White 1969 SS 396 Hugger Orange 1969 Z/28 All original White with deluxe interior 1970 RS Blue 1978 Coupe Fugly Green 1978 WS-6 Trans-Am Factory 4 speed 1985 IROC-Z Red |
06-29-2018, 02:59 PM | #4 |
Drives: 2012 Camaro RS 2LT 6spd man Join Date: Aug 2013
I use Mobil 1 advanced. viscosity depending on the weather. using 15W-50 now, sits in traffic at around 105-107deg temps. Water wetter in the radiator. Redline in trans(manual), redline in Differential. RBF600 brake lines Dot4. never had to flush my power steering....Always had a manual, cant tell you on the auto though.
The plugs go with OEM they are iridium from the factory. |
06-29-2018, 09:43 PM | #5 |
Drives: 02 Camaro B4C Join Date: Nov 2016
I've been running Amsoil in a wide range of vehicles and am very satisfied.
A man's garage is his castle
1969 Camaro SS 1970 Camaro SS 2002 Camaro B4C 2014 Camaro SS Dedicated Track Car 2015 Camaro 1SS 1LE 2008 HHR SS 1996 Silverado Crew Cab Long Bed Dual Rear Wheel |
06-29-2018, 10:12 PM | #6 |
I used amsoil but in all honesty oil doesn’t matter much if it’s full synthetic and frequent changes. Mobil 1, Valvooline, Castro’s GTX. Doesn’t matter. My differentials I went with Mobil 1 and AC Delco limited slip bottle and Redline D4 for tranny
Life is short, drive it like you stole it! |
06-29-2018, 10:27 PM | #7 | |
Drives: 2012 2SS Victory Red with white st Join Date: Jun 2016
Every one has their favorites for one reason or another. I use Mobil 1 for everything. Always have and never had a single problem. My 1993 has been ridden hard and ,,,well you know the rest. Over 212,000 miles on her and not one single issue. So, that is why I stick with it. I could care less about what is popular at this time. If it works, I use it until it doesn't. Spark plugs? You first need to find out what type your car requires from the owner's manual. Standard , iridium, and the list goes on. Also depends on your car and setup. Daily driver, weekend warrior? what? I personally use NGK as do a lot of other people on here. They will last 100k miles easy. You are def. doing the right thing keeping up with the maintenance. Kudos to you. Your car will last a long time.
06-29-2018, 10:42 PM | #8 |
Boosted Moderator
Personally I run Amsoil but we change it every 20-30 miles... unless it's just street driving then we might make it to 500 miles or so but thats horribly expensive at $15.00 a gallon and 3 MPG. So, I don't street drive very much and I change the oil before and after every racing event....
Spark plugs, I run NGK but for a very different reason....We change those every 8-10 miles depending on conditions... If your OE plugs last 100K miles, Why change brands.... Slap a new set in there and run it for another 100K miles....
If the car feels like it is on rails, you are probably driving too slow. -Ross Bentley
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
06-29-2018, 11:13 PM | #9 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
Amsoil was developed for jet engines in what, the 1950’s, when they were developed? Presumably these high RPM, (17,000 rpm) close tolerance engines, needed something superior. Fast fwd to the modern day and developmental cycle. Can’t go wrong with this product. In my opinion.
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
06-30-2018, 10:12 AM | #10 |
Drives: 2014 2SS blue Join Date: Jun 2016
There are no oils that will majically make your car go faster, longer etc, than other spec oils. Go with whatever oil you want as long as it meets the car spec. In the end, it won't matter. Just change it on the OLM schedule at the very longest. Lets face it, in another 100k miles, the lawnboy will be driving it, smoking, singing mariachi songs, with fastfood trash, beer cans, and used condoms on the floor, anyway. Use a good filter (Wix XP, Mobil 1, STP, Amsoil, Royal Purple, Fram Ultra Synthetic, other known good ones for synthetic oils)
06-30-2018, 09:06 PM | #11 |
Drives: 2012 Imperial Blue RS Join Date: Aug 2017
Now that’s funny!!!!
True....But funny! |
06-30-2018, 09:19 PM | #12 |
Drives: Camaro V6 Join Date: Oct 2016
07-01-2018, 11:05 AM | #13 |
Camaro #4
Drives: 2017-Hyper Blue Metallic-2LTmanual Join Date: Dec 2015
All my fluids (minus P/S, coolant/brake fluid) are Amsoil and I change at the OLM's reading. No issues. I'm at 80K and I'll either use factory replacements or NGK when it's time to do the plugs.
Don M
Supercharged LGX + 6 speed manual = FUN!! |
07-01-2018, 11:43 AM | #14 |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
92,000 Mile with Mobile one oils and Wix filters.
Change oil every 3,000-4,000 miles
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
Thread Tools | |
