08-26-2016, 11:45 AM | #1 |
Drives: 2016 Black 2SS Join Date: Jan 2016
Installed new exhaust and now have cel codes
So I have recently had a exhaust installed from behind the second cats. Now I'm throwing cel codes for the afms being disconnected and reconnected. I don't have a spot to mount the afms to so they are tied up and out of the way. I have cleared the codes multiple times but still keeps coming back. Codes are P069E/P12E8/P12FD. Any help would be great or questions as I have tried just about everything. I just dont want a tune for the simple fact to turn the afms off and void the warranty.
08-26-2016, 12:47 PM | #2 | |
The afm valves need to be grounded to the vehicle |
08-26-2016, 01:27 PM | #3 |
Thanks I didn't know that I just had them tied up. So that would explain it.
08-26-2016, 08:47 PM | #4 |
Well I mounted it and cleared the codes. After the second start up it pops back on. Any other suggestion
08-26-2016, 09:07 PM | #5 |
Drives: 2016 Camaro 1SS Red Hot Join Date: May 2016
08-26-2016, 09:11 PM | #6 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
http://m.autoanything.com/performanc...disable-device
Mind you read the bottom line, may still throw a cell. Save 20% Use Promo Code 139320 1-Year Lower-Price Guarantee Free Shipping In Stock - Ships Today Custom Fit For Your 2016 Chevy Camaro Change Options 6.2L V8, automatic transmission, with Active Fuel Management Part Number - RA003 Disables Active Fuel Management Does not reprogram ECU Note: Vehicle may occasionally register a Diagnostic Trouble Code (DTC) due to the high traffic volume on the bus (the communication system of the vehicle)
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
08-26-2016, 09:27 PM | #7 |
I'm running mbrp exhaust but it didn't have the afm valve placement so I remove the one from my old exhaust hollowed it out and welded it. Still getting codes
08-26-2016, 09:31 PM | #8 |
Drives: 2016 camaro ss Join Date: Oct 2010
You have to have the motors mounted to the valves. They check when powered on that they are functioning properly so i think they need to feel the resistance of that spring in the valve. That's why i don't understand why some aftermarket manufacturers are avoiding this. Now you have a CEL that can't even be tuned out with HP Tuners or any other tuning software. Your only option is to get another exhaust with afm valves or afm dummy mounts. Stainless Works has both options. The Range device mentioned above definitely will not do anything to help.
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS RIP : 2002 WS6 Black, A4, 355rwhp |
08-26-2016, 09:43 PM | #9 |
I'll figure out something to add some resistance in there
08-27-2016, 01:05 AM | #10 |
Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
The same valves causing rattle in my exhaust... they suck and I hear them move every time I get in the car before starting it (I usually remote start).
I'm sure someone could make a simulator plug for them if there was enough interest. Granted if you don't disable AFM at the motor, your exhaust will probably sound pretty hollow when in V4 mode. |
08-27-2016, 01:20 AM | #11 |
Yeah it does. But nan when it's in v8 mode that shit is awesome.
08-27-2016, 06:09 AM | #12 | |
I've found the exhaust sounds bassy and farty in v4 mode without afm valves. I prefer the valves so it gets quiet in v4 mode
