08-01-2016, 07:14 PM | #1 |
Drives: 2014 Camaro 1SS/RS A6 Join Date: Jun 2014
Remove brake backing plates for road course??
Yes it's a technical brake question, but I'm posting here to avoid answers from drag racers.
Has anyone, for use on a road course, removed the brake backing plates ("dust shields") from the front brakes? As an engineer, I understand these things serve various purposes, but I'm thinking they may block a whole lot of radiative heat transfer from leaving the back of the rotor. Potential problems I see include melting stuff behind the rotor (such as ABS sensor wiring) and/or allowing flaming pieces of brake pad to pierce the rubber brake line. I'm not interested in a brake duct debate (I have the Z28 brake ducts), just an answer of whether anyone has done this and whether it has helped with brake temperatures and wear. Thanks in advance!
Chris Werner
Author, "How to Rebuild GM LS-Series Engines" Contributing Editor, GM High-Tech Performance (1998-2014) |
08-01-2016, 07:15 PM | #2 |
Subscribing to my own thread.
Chris Werner
08-01-2016, 09:23 PM | #3 |
Drives: 2013 Camaro 1LE Join Date: Jul 2012
I think if you look at the ZL1/1LE/Z28 backing plates for the front they are very small and do not block/cover nearly as much of the back side of the rotor.
I just happened to have my 1LE up on the lift with the wheels off so I went out and snapped a few pics for you. I also believe that if you order the 6-piston brake upgrade kit from Chevrolet Performance Parts they send this smaller backing plate with because otherwise the standard backing plate would interfere with the caliper.
08-01-2016, 10:12 PM | #4 | |
5 92199929 SPLASH SHIELD, LEFT 6.2 LITER, W/O SUPERCHARGER, W/O PERFORMANCE PKG $7.28 $4.15 5 92199930 SPLASH SHIELD, RIGHT 6.2 LITER, W/O SUPERCHARGER, W/O PERFORMANCE PKG $7.28 $4.15 5 20944531 SPLASH SHIELD, RIGHT 6.2 LITER, W/O SUPERCHARGER, W/PERFORMANCE PKG $29.70 $16.93 5 20944532 SPLASH SHIELD, LEFT 6.2 LITER, W/O SUPERCHARGER, W/PERFORMANCE PKG $29.70 $16.93 5 20944532 BACKING PLATE CAMARO; W/SUPERCHARGER; LEFT $29.70 $16.93 5 92199930 BACKING PLATE CAMARO; W/O SUPERCHARGER; RIGHT $7.28 $4.15 5 92199929 BACKING PLATE CAMARO; W/O SUPERCHARGER; LEFT $7.28 $4.15 5 20944531 BACKING PLATE CAMARO; W/SUPERCHARGER; RIGHT $29.70 $16.93
Chris Werner
08-01-2016, 10:35 PM | #5 |
Drives: pleather and Chiclets Join Date: Mar 2012
I have been without them for some time. I was led to believe they are to protect those bushings more than anything else.
08-01-2016, 10:35 PM | #6 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
How are those held on? I heard the rears are held on by 3 tack welds?
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
08-02-2016, 01:03 AM | #7 |
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500 Join Date: Apr 2015
They are bolted on, between the hub and the spindle
08-02-2016, 09:00 AM | #8 | |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
Rears are the same as the 2SS -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
08-29-2016, 01:11 AM | #9 |
Drives: 2014 2SS 1LE Join Date: Jun 2014
while you are there, replace them with these.
never over heat the rotors again. http://www.jdpmotorsports.com/brands...aro-ss-13430cp |
08-29-2016, 07:43 AM | #10 |
slower than you
I didn't have to modify my front plates at all going from 4 to 6 piston.
08-29-2016, 10:14 AM | #11 |
You already had a 1LE which came with the smaller backing plates. The regular SS's came with the larger backing plates.
08-30-2016, 12:27 AM | #12 |
slower than you
Ah, I mis-read :(
08-30-2016, 10:53 AM | #13 |
Since I have a set of CTS-V Calipers coming these would a nice addition to make it correct???
Orange Krush II
Thread Tools | |
