07-24-2016, 09:45 AM | #57 |
Drives: 2014 M6 ZL1 Join Date: Jan 2012
As much as we would all like to see a higher stock LT4 number, I think it will be doubtful from GM. The limiting factor may be the smaller pullied 1.7L blower and the heat it generates. The Corvette Guys were left with an inefficient design, that Cadillac improved on, and Chevy probably solved in the new ZL1.
The C7 ZO6 Guys are already Installing an aftermarket blower and intercooler to push past what they've been given.
15' Ashen Gray Metallic Z/28
14' Crystal Red Tintcoat ZL1 6M, 9.62 at 150.75 MPH 12' Opulent Blue Metallic CTS-V Sedan, 10.690 at 129.60 MPH - SOLD 06' LeMans Blue Metallic Z06, 11.726 at 127.80 MPH Motor - SOLD. 96' Impala SS LTx, 11.397 at 118.10 MPH Motor, 1st stage 10.526 at 127.46 MPH |
07-24-2016, 10:42 AM | #58 | |
Drives: '69 RS Pro Street Join Date: Feb 2016
Just curious since the claim now is that the ZL1 should be an improvement but does anyone really know that? I think not. |
07-24-2016, 12:14 PM | #59 |
Not sure what you are asking, but if you are referring to heat soak issues in the C7 Z06. There are several threads on Corvette forums and independent tests where the Car Goes into limp mode during heat soak after 1 lap during track days.
The 3rd gen CTSV has the same motor with better cooling in a heavier platform. These new Caddys arent seeing this, but there are a lot less on the Road and not many owners running them on road course track days. If you look how low the LT4 has to sit in the C7 Z06 and the limited front end cooling compared to the 3rd gen CTSV and new ZL1, those are some of the differences on how GM is solving the heat this small pullied blower makes.
07-24-2016, 12:53 PM | #60 | |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
We've seen that the 2017 CTS-V and ZL1 will get a taller lid and the Z06 will also get changes. I'm hoping there will be bump in power associated with the "other changes".
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
07-24-2016, 01:24 PM | #61 | |
07-24-2016, 01:28 PM | #62 | |
Drives: Charger Hellcat Join Date: Apr 2016
07-24-2016, 02:12 PM | #63 |
Drives: AUDI 80 Join Date: Jul 2015
the main problem with chevy´s Z06 is due to its bad eficiency with only 2valves/cyl.
The rest goes through heat and have to be cooled down which gives the next problem in small chassis. And as a top of bad engineering they put on a to small high revving blower which heat up the inlet air more than it should be. I swear Fords coyote with a 2.9 ltr. whipple would do much better in the Corvette with no overheating and same cooler size. |
07-24-2016, 02:26 PM | #64 | |
America FVCK Yeah!
Drives: 2021 ZL1 1LE A10 Join Date: Mar 2013
EDIT: Only the Porsche 918 for $845,000 can match its track time and lack of gas guzzler. And we all know how Audi made its engines more "efficient". The issue is over spinning a 1.7L PDB + a low hood and limited front section. Tadge says he and the engineers have it solved for 2017....we'll see. Last edited by cvp33; 07-24-2016 at 03:51 PM. |
07-24-2016, 03:52 PM | #65 | |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
07-24-2016, 05:20 PM | #66 | |
Rockcrusher
Drives: 2017 SS 1LE Join Date: May 2009
07-24-2016, 09:30 PM | #67 | |
I truly believe the new ZL1 and current CTSV have solved the overheating issues that are effecting the C7 Z06 when run hard on track days. GM put a heat protect mode in this Vette and also didn't allow it to be reved over 5000 rpm during the break-in period. That tells me they knew they had a problem but still had to build safeguards in the design to protect against excessive warranty claims. I believe we are going to get the 3rd and best iteration of the LT4 design and packaging inside an outstanding platform. I wouldn't worry about it.
07-25-2016, 12:50 PM | #68 |
Drives: 2015 Sierra Join Date: Apr 2016
The 1.7 makes more hp/torque under the curve than the 2.3, that's why they went with that blower.
07-25-2016, 03:35 PM | #69 | |
Drives: 1992 Z28 1LE; 2015 Zl1 Join Date: Mar 2009
The heads are not even on the list of problems with the Z06. The small chassis is one of the positives of the Vette although it doesn't help the cooling issue. The high revving blower is an issue. I'm not sure the coyote with S/C would fit without doing some of the things they are doing anyway to fix the heat issues in the Corvette.
1989 Camaro RS convertible- Sold
1999 Camaro SS - Stolen 2x 1991 Camaro Z28- 1991 Camaro Z28 1LE- 1992 Camaro Z28 1LE- 25th anniversary 2015 Camaro ZL1 |
07-30-2016, 09:17 AM | #70 |
I believe we have our answer
Thread Tools | |
