Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Gen5DIY
Old 08-25-2014, 10:14 AM   #1
Tran
Administrator
Tran's Avatar
Drives: 2010 Camaro of course....
Thumbs up 2016 Camaros spied running with 5th gen Camaro!
Our spies have captured some 2016 Camaro prototypes running with the current model, giving us our first real-world chance to compare Camaros riding on the new Alpha architecture versus the current Camaro and its Zeta-based architecture.
While a photographic encounter with a group of prototypes hell-bent on evading the lens doesn't necessarily lead to a scientific study of cars' dimensions and proportions, we do come away with some impressions that next-gen Camaro will see some subtle downsizing over the current model. We'll leave you to your own impressions of what the photos suggest, as to the overall effect that the Alpha architecture will have on the 2016 Camaro's dimensions and curb weight.
The large Camaro contingent consisted of several prototypes, both with quad- and dual-exhaust set-ups, suggesting a mix of V6- and V8-powered prototypes. Once again, our photographers were struck by the proper muscle car sound of the prototypes as they tore past their lens.
The new frontal shots give some new clues to the new Camaro's front-end design, along with a glimpse of some LED light strips in the prototypes' front bumpers.
Tran is offline   Reply With Quote
Old 08-25-2014, 10:21 AM   #2
Tran
Administrator
Tran's Avatar
Thumbs up
Old 08-25-2014, 10:34 AM   #3
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Missed one of the signs blocking our where they were taken........LOL
Along M-59 in near the proving grounds I suspect.
Interesting thou.
rtcat600man is offline   Reply With Quote
Old 08-25-2014, 11:02 AM   #4
DRKS1D3
DRKS1D3's Avatar
Drives: 2011 Camaro SS Convertible LS3
When there aren't any Earth-shattering changes, some people may freak out that were expecting more of a change.
MY RIDE: 2011 TRIPLE BLACK SS CONVERTIBLE (BOUGHT NEW 4-2011)--6 SPEED MANUAL, K&N TYPHOON INTAKE, FLOWMASTER FORCE II MUFFLERS, HOTCHKIS SUSPENSION, BLACKED OUT BOWTIES, GLOSS BLACK 20x9 STYLE 41 WHEELS, 285-35-20 GOODYEAR EAGLE SUPERCAR G2'S, JBA HIGH-FLOW CATS, BBK HEADERS, LUNATI CUSTOM GRIND CAM: 227/235 .619/.626 114 +3
DAD'S RIDE: 2012 ZL1 #1866 (BOUGHT NEW 6-2012)--BLACK, 6 SPEED, EXPOSED CF HOOD, POLISHED WHEELS, SUNROOF, ROTO-FAB INTAKE
"Silly Americans, taking from the rich and giving to the poor only works in fairy tales. Success is earned here!".
DRKS1D3 is offline   Reply With Quote
Old 08-25-2014, 11:08 AM   #5
KMPrenger
KMPrenger's Avatar
Sweet! I love seeing more photos coming in!
Old 08-25-2014, 11:19 AM   #6
Cpt Jack
Drives: 2012 Camaro SS
Thanks for the pics. My interest for this new model is starting to ramp up!
I think they should take heed of some of the lessons learned from the new Mustang launch which I have been following too. Gotta manage expectations with this so people don't freak out if it's not the golden unicorn that rumors tend to always suggest.
It's too early to say with these photos but it wouldn't shock me if it doesnt change TOO much. Don't fix what isn't broken?
Cpt Jack is offline   Reply With Quote
Old 08-25-2014, 11:26 AM   #7
TommyTheCat
SHKE BKE ☪
TommyTheCat's Avatar
Drives: 2013 Camaro
It sort of looks like the low and high beams may be run on separate bulbs that look like completely different housings altogether. Also looks like the grille shows through a couple pics and is similar to the 2014 but separated in the middle...
Could be completely different
TommyTheCat is offline   Reply With Quote
Old 08-25-2014, 11:50 AM   #8
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Interesting, can't really tell much on the test mules. The part of the front bumper that you can see through under the camo looks a little weird. Really narrow at the top..
BaylorCamaro is offline   Reply With Quote
Old 08-25-2014, 11:53 AM   #9
Bhobbs
Bhobbs's Avatar
I'm surprised they don't take video of these things.
Is that the muffler hanging between the exhaust pipes?
Old 08-25-2014, 11:56 AM   #10
87GNX
87GNX's Avatar
Drives: Alot
Ready for this car.
IF YOU AIN'T FIRST, YOU'RE LAST
87GNX is offline   Reply With Quote
Old 08-25-2014, 12:11 PM   #11
Sean@Phastek
Sean@Phastek's Avatar
Drives: 2010 Camaro X5 Turbo
I see a special muffler on the #6 car.... turbo 4-cylinder model testing?
Sean@Phastek is offline   Reply With Quote
Old 08-25-2014, 12:19 PM   #12
forklord
forklord's Avatar
Drives: 2010 2SS
Man that rear windoe really sits inside the padding like 6" or so. I still think the front looks like a gen3/4 mashup
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 08-25-2014, 12:25 PM   #13
fradaj
Drives: RS
Looks about 2" lower and narrower, hopefully it will keep the same proportions as the C5. Looks like they are using the same tires used on the 1LE. I am expecting a fairly significant change in the styling but also maintaining the character of a Camaro. Still no way to tell what it looks like until more of the camo comes off.
fradaj is offline   Reply With Quote
Old 08-25-2014, 12:30 PM   #14
Mersades
Web Geek Chick & NHRA fan
Mersades's Avatar
Drives: 2010 2SS LS3 RJM
I spy Impala-like day lamps.
Mersades is offline   Reply With Quote
2016 camaro, 2016 camaro forum, 2016 camaro forums, 2016 camaro spy, 2016 camaro spy photo, 2016 camaro spy photos, 2016 camaro spy pics, 2016 chevrolet camaro, 2016 chevy camaro, 2017 camaro, 2017 chevy camaro, 6 gen camaro, 6th gen camaro, 6th gen camaro forum, 6th gen camaro forums, 6th gen camaro info, 6th gen camaro news, 6th gen camaro rumors, 6th gen chevrolet camaro, 6th gen chevy camaro, 6th gen chevy camaro forum, 6th generation camaro, 6th generation camaro info, 6th generation camaro news, 6th generation camaro rumors, 6th generation chevy camaro, camaro 6th gen, camaro 6th generation
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
