Old 07-15-2014, 11:50 AM   #1
Xp0gam3r
Xp0gam3r's Avatar
Drives: '15 2SS 1LE; '10 2LT RS
Question 2016 ATS-V - Could this be the dimensions of the 6th Gen Camaro?
I just saw the spyshot pics posted on roadandtrack.com of new 2016 ATS-V. Is this the size/dimensions we should expect for the 6th Gen Camaro?
http://www.roadandtrack.com/go/futur...-shots#slide-1
2016 Cadillac ATS-V Coupe drops body cladding for 'Ring run
The recipe for the 2016 Cadillac ATS-V Coupe is the same as the sedan: a 400+ hp twin-turbocharged 3.6-liter V6, beefy tires, a harder-core suspension, and big, fat flares. There's virtually no chance it will be anything less than awesome. Check out 6 pics
Xp0gam3r is offline   Reply With Quote
Old 07-15-2014, 12:20 PM   #2
stt816
Drives: 2012 Black 2SS/RS M6
interdasting
Pfadt Race Engineering 1.25" Lowering Springs| Pfadt Spec Performance Street Alignment|ZL1 Front Bumper Conversion|ZL1 20x9 Rims|Pirelli P Zero All Season Plus 275/40R20Y Square Setup||Footwell Lighting|G2 Gold Painted Brake Calipers
Stainless Power Long Tube Headers|Cold Air Inductions Cold Air Intake|VMAX CNC Spiral Ported Throttle Body|Stainless Works Retro Chambered Catback| Vitesse Throttle Controller
--Jannetty Racing Enterprises Dyno Tuned|408 RWHP
stt816 is offline   Reply With Quote
Old 07-15-2014, 12:42 PM   #3
KMPrenger
KMPrenger's Avatar
Also, isn't the wheelbase on the coupe 1" wider than the sedan? I think that is kind of interesting.
I'd like to think we'd see the Camaro sized in between the ATS and the CTS, as I don't see why the car would need to be CTS sized (it needs to get smaller if anything!) but then again can the Camaro, with its long hood body style fit on the ATS chassis? I don't know what to think..
Problem is I don't know if GM would go through the added expensive of creating another version of Alpha for Camaro would they?....so it could be one or the other.
All I know is, the Camaro does NOT need to increase in size, and it NEEDs to lose a few hundred lbs if at all possible. Those who seem to be in the know say it is shrinking, so take that as you will.
Old 07-15-2014, 12:48 PM   #4
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
would have loved to see the twin turbo 6 in the new camaro
Old 07-15-2014, 01:34 PM   #5
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
I find it interesting that that ATS has ZL1 style wheels...
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can and Clean Side Separator, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I, ACS TL1 Hood Insert, ZL1 Spoiler
DSX_Camaro is offline   Reply With Quote
Old 07-15-2014, 01:41 PM   #6
Need4speed_motorsports
Need4speed_motorsports's Avatar
Drives: 2016 Camaro SS
Cant wait till this spanks the M3 and M4
Need4speed_motorsports is offline   Reply With Quote
Old 07-15-2014, 01:44 PM   #7
toesuf94
toesuf94's Avatar
Drives: THR #11 E-force supercharged
Send a message via MSN to toesuf94
I find it also very interesting that the calipers are disguised as well! Camaro Mule?
Cars and women are both going to give you problems...but you can pay somebody else to fix your car!
toesuf94 is offline   Reply With Quote
Old 07-15-2014, 01:46 PM   #8
PoorMansCamaro
Drives: Really Slow
Old 07-15-2014, 03:18 PM   #9
DenverTaco07
DenverTaco07's Avatar
Couple of reports, though conjecture at this point, are all saying TT V6 in the ATS-V.
Assuming this is true, and Camaro also goes on ATS wheelbase...no V8?
Old 07-15-2014, 03:22 PM   #10
PoorMansCamaro
Drives: Really Slow
pretty sure the new Camaro will get the LT1, at the very least.
Old 07-15-2014, 03:31 PM   #11
Bhobbs
Bhobbs's Avatar
The Alpha platform was designed to handle V8s. The CTS-V is more than likely going to have a forced induction V8.
There are rumors of an ATS-V+ getting a V8.
Old 07-15-2014, 03:35 PM   #12
DenverTaco07
one would hope, LT1 for SS, LT4 for ZL1...
I'm by no means an expert, but I assume - based on other threads here, there is no issue in putting an LT1 or LT4 on the ATS alpha.
The ATS-V size is growing on me - i thought it would be too small as i have loved the CTS-V for years now, but it is looking pretty mean even with all the camo.
Old 07-15-2014, 03:43 PM   #13
bork_bork
bork_bork's Avatar
Drives: 2013 ZL1 M6 Convert Triple Black
Not a fan of the color
bork_bork is offline   Reply With Quote
Old 07-15-2014, 04:31 PM   #14
DenverTaco07
yeah...black with white swirls would look much better.
