04-13-2014, 09:20 AM | #1 |
Drives: 2013 ZL1 Join Date: Dec 2013
Intake and Throttle Body Issues
I have been reading about intakes and I am sold. So I am looking at doing the Vmax TB at the same time. What's holding me back is a few people seem to be having some idle issues without a tune.
Here is a prime example: Roto-fab intake and Vmax TB with idle issues Is anyone running that here without a tune? Did the idle issues go away? |
04-13-2014, 10:51 AM | #2 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
He may have pinched the oring seal when putting the TB on. I did that once installing a ported TB on a 06 GTO.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
04-13-2014, 11:13 AM | #3 |
I am running that exact combo. I did do a fuse pull the night before the install and let the car warm up to relearn the idle for 15 min before driving. I have not had any issues at all.
Dave |
04-13-2014, 11:37 AM | #4 | |
Drives: 2011 SS Join Date: Jan 2014
No need for a tune at all. Just a strong MAF sensor |
04-13-2014, 11:41 AM | #5 |
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM Join Date: Oct 2010
I've sold several hundred Vmax throttle bodies and installed about 50 locally. I haven't seen that issue, and even though I have HP tuners , I haven't had to do any relearn procedures, or unplug the battery. Zero of them had issues.
I move the intake tube out of the way, unplug the throttle body connection, remove the four slightly tightened throttle body bolts, remove the stock throttle body and reverse the process with the Vmax throttle body in place and start the start the car, get paid, owner droves off happy with much better throttle response. Its really a 20 minute install that's that easy. Of the over 5000 units sold, The rarely heard of problem is mostly caused by a air leak between the new air intake installed and the front of the throttle body where unmeasured air is leaking in |
04-13-2014, 12:42 PM | #6 |
Drives: 2013 Camaro ZL1 (IOM) Join Date: Oct 2012
I have the Cold Air Inductions, Inc. CAI with the VMAX ported throttle body and no tune.
There were no idle issues at all after the install. |
04-13-2014, 01:05 PM | #7 |
Drives: 2013 ZL1 A6 Join Date: Nov 2013
I installed K&N kit with Vmax throttle body, no fuse pull, no battery disconnect and I have had Zero issues. Also did APex catch can all at the same time. Only difference has been a huge difference in throttle response and seat of the pants feel. And supercharger whine sounds awesome!
04-14-2014, 09:20 AM | #8 | |
Drives: 2000 Camaro SS Join Date: Feb 2010
04-14-2014, 12:04 PM | #9 |
Snake Eater
Drives: 2012 AGM ZL1 Join Date: Oct 2011
I just installed the Roto fab this past week with no problems. Looking forward to swapping the TB soon, hate that its 350 though instead of just 150.
Build Thread: http://www.camaro5.com/forums/showth...95#post8351295
Make sure you don’t forget to subscribe to my channel! More content on the way. Like, share with your friends https://www.youtube.com/channel/UC9Z...sP2wjsLLFeP1zQ Follow me on instagram: http://www.instagram.com/snkeatr/ |
04-14-2014, 12:12 PM | #10 |
04-14-2014, 08:06 PM | #11 |
Sounds as if maybe something is loose and there is a vacuum leak, the Ecu will hunt for throttle position trying to compensate for the un metered air entering the engine
Thread Tools | |
