Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 09-12-2013, 08:22 PM   #15
Southern Comfort
No Tags/Habitual Violator
Southern Comfort's Avatar
Drives: 2012 SIM 2SS/RS & z71
How different is it in mild mode? Contemplating adding this control as well.
Southern Comfort is offline   Reply With Quote
Old 09-12-2013, 08:25 PM   #16
Jims73z
Jims73z's Avatar
Drives: 1973 z28 Rs , 2012 SS/Rs Blk/Blk M6
I have the switch but haven't installed it yet. I'm thinking a project for tomorrow. Working on upload of video before and after I did today. Stay tuned.
Jims73z is offline   Reply With Quote
Old 09-12-2013, 11:47 PM   #17
Jims73z
Jims73z's Avatar
http://youtu.be/p_kgPK-ZmxI
Old 10-09-2013, 07:10 PM   #18
phk36
phk36's Avatar
Drives: 45 th 2ss convertible
Hi, where do you by the npp mufflers ? also ca you just install a mild to wild to work them without the vacume ?
Any one try it with the factory ground effect kit ? they say it will not fit but it looks like it will . A cat back npp is close to 2k from what the dealer told me Thanks , Pete
phk36 is offline   Reply With Quote
Old 10-10-2013, 09:57 AM   #19
Deke736
COTW 12/3/12
Deke736's Avatar
Drives: 2012 Ashen Gray ZL1
PM 2SSRS@Gen5diy for the exhaust, or just keep an eye out in the used section. There's been a few of them for sale lately. I also don't think just a mild to wild switch will work. You'll need a vacuum system described above or will need to purchase the electronic kit that is available. It runs over $200. You should be able to find the axel back exhaust for around $400 or less. I've seen a few for a round $350.
I don't know about the factory GFX.
Deke736 is offline   Reply With Quote
Old 10-10-2013, 11:22 AM   #20
Southern Comfort
I ordered the switch but they cancelled my order and refunded payment. Must be gonna be out of stock for the foreseeable future.
Old 10-10-2013, 01:14 PM   #21
Anaconda
Anaconda's Avatar
Drives: 2013 Camaro 1SS 6-speed VR
Any worry on the hoses becoming loose or corroded due to weather, heat or other factors with time? I saw some other instructions on the Exhaust Commander NPP retrofit kit and they're running hoses down under as well. Not sure if that's the way it is on stock cars already equipped with NPP.
2013 Victory Red 1SS 6-speed w/ black stripes ordered 8/15/12
Delivered 10/2/2012!
Corsa ZL1 catback exhaust, Black CAI intake with scoop and washer bottle relocation
Anaconda is offline   Reply With Quote
Old 10-10-2013, 05:48 PM   #22
Deke736
COTW 12/3/12
Deke736's Avatar
There's no clamps on the stock system, but if you were worried about it you could install them. I can't see why there would be any corrosion issues since it's just rubber vacuum hose pugged into an aluminum actuator. The stock system on my ZL1 looks fine after 1-1/2 years using the same method of attachment from the factory.
Old 10-10-2013, 07:00 PM   #23
Anaconda
Anaconda's Avatar
Cool was just checking.
Old 10-12-2013, 05:56 PM   #24
phk36
phk36's Avatar
Thanks Deke76 I will email him. I have been looking and if I can find a cat back under a grand I will jump on it and also install the vacume line
Old 10-30-2013, 11:16 PM   #25
was619
Billy The Kid
was619's Avatar
Drives: Cyber Grey 2SS/RS
Is there a way to just buy the npp valves as to hook up this function on non OE mufflers?
Thanks!
CGM 2SS/RS[SIZE="1"]
Performance: LT Headers/Stainless Works cat-back, 225/233 Cam, 1LE 3.91 gears, Custom Tune, BMR suspension,
MGW Shifter, Stainless brake & clutch lines, Ideal G Master Cylinder, 275s on all 4 corners
Aesthetics: ZL1 Spoiler, DIY LED marker lights, AACPlasma DRL, Yellow Calipers, painted factory wheels
was619 is offline   Reply With Quote
Old 01-14-2014, 07:13 PM   #26
ilirg
ilirg's Avatar
Drives: 2011 Camaro 2ss
Ok im planning on doing this, can I set it to have the butterflys closed at all time?
ilirg is offline   Reply With Quote
Old 01-14-2014, 07:58 PM   #27
Jims73z
Jims73z's Avatar
Not really. When the car starts they are open till the vacuum build up and closes them. They also open up under full throttle when the vacuum drops enough.
Old 01-21-2014, 01:11 PM   #28
ilirg
ilirg's Avatar
OK got my zl1 exhaust, all the vacuum hoses and vacuum switch. Quick question, does it make a difference which port on the switch the vacuum lines go in? And does the button on the switch need to be pushed down or pulled out to work with bi-mode. Can't wait to do this, damn snow through a wrench in my plans today.
install, npp, tap, vacuum
