Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Go Back   CAMARO6 > CAMARO6.com General Forums > 2016 Camaro: 6th Gen Camaro general forum
BORLA
Old 03-13-2013, 10:45 AM   #15
FenwickHockey65
General Motors Aficionado
FenwickHockey65's Avatar
Drives: 2003 GMC Envoy/2007 Ford F-150
Zeta and Epsilon II both come to mind as platforms that needed weight reduction yesterday. It's one of the main problems with the new Malibu.
FenwickHockey65's GM Thread!
2003 GMC Envoy SLE - Airaid Cold Air Intake, Gibson Performance Catback Exhaust
2007 Ford F-150 XL SuperCab (State-issued)
Old 03-13-2013, 10:59 AM   #16
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
We only complain because the weight shaving is not enough. We want a feather light 500HP camaro that takes off the line like a rocket and blows the competition away like a hurricane
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 03-13-2013, 11:14 AM   #17
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
As far as complaining, just sounds like this CEO order sort of came out of left-field...All plans for the next Gen Camaro were already in place...now this...
...Shave-off, down-size, reduce weight...all good...(just don't do it in the engine compartment!)...lol
Old 03-13-2013, 11:16 AM   #18
FenwickHockey65
Alpha was what kicked off the weight reduction campaign at GM. And the 6th gen is Alpha based, so...I don't see what the problem is.
Old 03-13-2013, 11:21 AM   #19
90503
90503's Avatar
Not arguing with you, brother...Just previous posts show 15% didn't jive with even the Alpha...all guessing on our end what it's all really about, of course...
Old 03-13-2013, 11:30 AM   #20
Wizard1183
Wizard1183's Avatar
I think that's the biggest issue. They rely on putting in a smaller engine to reduce most of the weight. Why not reduce it on the body, interior and components rather than engine weight reduction by throwing in a 4 cyl? That's how you satisfy. Engineers need to reduce chassis weight by 15%. Make it weight approx 3200lbs minus the engine. You'd be around 3450-3600? And that's a v8!
Old 03-13-2013, 12:13 PM   #21
FenwickHockey65
They already are reducing weight in the chassis and body.
Old 03-13-2013, 12:16 PM   #22
fielderLS3
fielderLS3's Avatar
Drives: 2016 Mazda6, 2011 Mustang 5.0
Yes, we've been screaming for weight reduction on this forum, but weight reduction for the sake of increasing performance and the driving experience. Weight reduction by removing half the engine was not what we had in mind, and would seem to run counter to the goal we had in mind.
"Proven V-8 power with better efficiency than a turbo V-6"
"The car is the closest thing we will ever create to something that is alive."eds.
fielderLS3 is offline   Reply With Quote
Old 03-13-2013, 12:19 PM   #23
FenwickHockey65
Using the 2.0T isn't the only method employed to reduce weight. Did any of you follow Alpha development at all? The measures GM took to reduce weight in the chassis were close to ridiculous.
Old 03-13-2013, 12:49 PM   #24
IMJ
IMJ's Avatar
Drives: 2012 SS LS3 | Silver Frost Metallic
Ya, it's silly to reduce weight as a goal only to have that manifest in a smaller, less capable engine struggling harder to pull a car of the same weight class around as before.
The steel stamping in this car is already pretty thin as I understand it, but why aren't there better materials for frame connections and stability, other ways in the body construction to reduce weight? It's not impossible....
Ironman John
IMJ is offline   Reply With Quote
Old 03-13-2013, 12:58 PM   #25
KMPrenger
KMPrenger's Avatar
As it is currently, a V8 Camaro on Alpha should be between 3,500 to 3,600 lbs...closer to 3,600.
Old 03-13-2013, 01:27 PM   #26
Wizard1183
Wizard1183's Avatar
Post
I hope that's WITH the automatic tranny and a good increase in HP. It should be no more than 3600lbs and have 500 HP. That's ideal.
Old 03-13-2013, 01:31 PM   #27
chef-beavis
chef-beavis's Avatar
Drives: IOM 2013 2SS/RS, Greenie, 06 FXSTBi
I'm not saying it's good or bad, either way, but all of the people demanding huge weight cuts on this car are also screaming there's too much plastic, the paint is too thin, the body dents too easy, etc. You can't expect to have your cake and eat it, too. Life is full of compromise; so is engineering and manufacturing.
It's coming whether we like it or not. I'm glad I've got mine. I hope for good things to come for the rest of you. If you only car about weight and performance, start removing components that don't figure into that equation. Making the chassis thinner just leaves you with a noodle, at some point.
chef-beavis is offline   Reply With Quote
Old 03-13-2013, 02:06 PM   #28
Wizard1183
Wizard1183's Avatar
Isn't that why the camaro SS was produced? For performance? Both the mustang and challenger outperform the SS. Now I understand the challenger has 45HP more than an SS but a mustang has less HP and out performs it. If you're buying the car for looks alone then get a V6. Guys who want the muscle performance from the factory should get just that. It's a war, but the camaro SHOULD outperform in many categories. And weight has become an issue that they can cut back on.
2015 camaro, 2015 camaro forum, 2015 camaro forums, 2015 chevrolet camaro, 2015 chevy camaro, 2016 camaro, 2016 camaro forum, 2016 camaro forums, 2016 chevrolet camaro, 2016 chevy camaro, 2017 camaro, 2017 chevy camaro, 6 gen camaro, 6th gen camaro, 6th gen camaro forum, 6th gen camaro forums, 6th gen camaro info, 6th gen camaro news, 6th gen camaro rumors, 6th gen chevrolet camaro, 6th gen chevy camaro, 6th gen chevy camaro forum, 6th generation camaro, 6th generation camaro info, 6th generation camaro news
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
