Go Back   CAMARO6 > CAMARO6.com General Forums > 2016 Camaro: 6th Gen Camaro forum, news, rumors, discussions
Old 02-17-2013, 09:37 AM   #1
90503
Drives: 2011 2SS/RS LS3
2016 6th Gen SS (V8) "Upgrades"...
Just curious...If the new Gen6 is smaller, lighter, handles better, etc., how would the hp/torq/0-60, etc. compare to the Gen5?...I've heard code numbers for other V-8's (LS7, whatever), what are we talking in c.i. or horsepower?...Will the LS3 or L99 be unchanged in the Gen6...
(Sort of burned out on the I-4 thing, so what about the "big-dog" engines that may go in the Gen6?)...Thanks...
Old 02-17-2013, 09:42 AM   #2
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: `12 LFX/`11 EB F-150/`13 Sonic RS
I think the LT1 will probably find its way into the Gen6. We don't know how much HP/TQ it will have when certified, but if GM's estimates of 450 are right then it should be very impressive in an approximately 300 lb lighter car. Only time will tell if the alpha platform is the choice for the Camaro and if you can fit an LT1 in it. I'm hopeful.
EFR Twin Turbo LFX-GPI Tune-ZL1 fuel pump-10:1 CR forged pistons-3.45 gear-Meth Injection-BMR Trailing Arms, Bushings & Sway Bars-CircleD 4000 Stall-GPI Fuel Enrichment System
647 RWHP & 726 RWTQ @18.5 psi on 93 Octane (locked converter)
1/8 mile -- 7.158 @ 102.10 (20psi); old build
Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 02-17-2013, 11:48 AM   #3
KMPrenger
KMPrenger's Avatar
Drives: '10 ABM LT/RS, 06 Chevy Colorado
Agree with gretchen. LT1 should make its way into the 6th gen. With the lighter weight there wouldn't have to be any more power than the current car to be a better performer...especially since the LT1 makes even better torque down low than the LS3 and L99 do.
If it comes in at 450/450 it will be a killer machine.
IPF Tune, Custom Magnaflow Exhaust, Vararam intake, MACE Ported Manifold, RX Ported TB, "Black Ice" manifold insulator, Elite Catch Can, ZL1 repro wheels, ZL1 Springs, DRL Harness, Front GM GFX, Heritage grill, Street Scene lower grill, NLP Spoiler, ZL1 rockers and much more!
Old 02-17-2013, 12:46 PM   #4
90503
Sorry for not knowing...but an LT1 is a what...V-8,...6.2 liter?...crank hp?...currently being used in Vettes???....a newer version of LS3?...
Old 02-17-2013, 01:04 PM   #5
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
Here is a good write up ...
SlingShot is offline   Reply With Quote
Old 02-17-2013, 01:04 PM   #6
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
Here is some interesting reading
http://wot.motortrend.com/next-gen-l...ch-280365.html
BigBlock69RS is offline   Reply With Quote
Old 02-17-2013, 01:04 PM   #7
mikeyg36
The GT Troll Hundred
mikeyg36's Avatar
Drives: Cammed 2012 AGM 2SS/RS LS3
It is a brand new Gen V small block used in the C7 Vette. It is 6.2 liters with direct injection, VVT, and the dreaded AFM. GM estimates it with 450 HP 450 TQ. Apparently the torque curve is close to the LS7.
Click For Build Thread ***CAI Intake, ARH LTs, FSP Big NA Cam, Tuned By Matt@FSP***
mikeyg36 is offline   Reply With Quote
Old 02-17-2013, 02:35 PM   #8
90503
Read the above links...thanks, boys...(sounds like they were written by the same guy, or they paraphrased the same press release...lol)...Anyway, sounds like a "better" engine...
...Didn't see any disclaimer about the AFM not being in manual cars...it was mentioned as akin to the L99 ...(Not sure what the case is with the 'Vettes)...AFM with a manual trans, would that even be possible?...
Old 02-17-2013, 05:04 PM   #9
90503
Originally Posted by karguy View Post
The new direct injected V8 is not necessarily better.AFM...
Which makes me think why would GM go through the additional cost of direct injection (as in a more expensive higher pressure pump) if the engine really doesn't make more power (additional variable valve timing) or get better mileage without AFM...
Also on direct injected engines intake valves can get more carbon buildup on intake valves since there is no gas that can clean them.
Another hint may be Porsche.While the new regular 911 get direct injected engines,the new sports GT3RS will have not direct injection.
Direct injection might be another gimmick for maybe slightly cleaner emissions...who knows?
Was thinking about AFM only...which my understanding is what shuts off the 4 cylinders...V-6s now have direct injection, without AFM, no cylinder shut-down...V-8's have L99 with AFM, LS3 does not have AFM...Wondering about the LT1, cylinder shut-down with both automatic and manual trans?, or AFM (cylinder shut-down) with the manual trans also with the LT1....
Old 02-17-2013, 05:10 PM   #10
mikeyg36
mikeyg36's Avatar
Both manual and auto... That's why the LT1 makes me sick
Old 02-17-2013, 05:43 PM   #11
SlingShot
SlingShot's Avatar
One of the big things is the difference in power curves between DI and non DI engines. If you look at a dyno graph the HP has a curve where the TQ is flat in the DI engine. I believe the AFM will be used just to save on the GG tax.
Old 02-17-2013, 05:45 PM   #12
mikeyg36
mikeyg36's Avatar
It's being used to raise the CAFE ratings. The Corvette doesn't have GG tax to begin with.
Old 02-17-2013, 05:59 PM   #13
SlingShot
SlingShot's Avatar
The ZR1 does ... But who know as far as the 2014, prices haven't been released yet.
Old 02-17-2013, 06:58 PM   #14
mikeyg36
mikeyg36's Avatar
Just saying, if an LS3 based Corvette doesn't have it, a non afm based LT1 wouldn't have it.
Old 02-17-2013, 07:09 PM   #15
90503
Wow...If AFM is on all V-8 LT1 Gen6 Camaros...that is cause for concern...maybe the Vette boys have found a way around it already, or perhaps soon...
On another note, this direct injection business.....the LFX V-6 Camaros have that already...(seems to be a plus), but also means no after-market headers????...wonder if the same would be the case on direct-injection LT1s...
Old 02-17-2013, 07:17 PM   #16
GretchenGotGrowl
LLT is DI and you can have headers. LFX also has the exhaust manifold integrated in the heads, that is why they can't do headers.
Sent from my SPH-D710 using Tapatalk 2
Build Thread
Old 02-17-2013, 09:14 PM   #17
sspolo
sspolo's Avatar
Drives: None at the moment :'(
Does the Camaro and Corvette share the same engine? From what I understood, the ZR1 has the LS9, the Z06 has the LS7. Does the base Corvette have the LS3? If it does, I would have imagined the Camaro SS having an "inferior" engine in comparison to the base Corvette.
sspolo is offline   Reply With Quote
Old 02-17-2013, 09:15 PM   #18
mikeyg36
mikeyg36's Avatar
Yes, base Vette has the LS3 and the Grand Sport Coupe has a dry sump LS3.
Old 02-18-2013, 11:06 AM   #19
90503
Ok...so let's say this LT1 engine is the "standard" V-8 for the 6thGen SS...
...any rumors, or whatever about other V-8 options?...LS7? LS3, is done with?...Could these be special ordered???...just hoping some V-8 would be available without AFM...
Old 02-18-2013, 11:13 AM   #20
FenwickHockey65
General Motors Aficionado
FenwickHockey65's Avatar
Drives: 2003 GMC Envoy SLE/2007 Ford F-150
LT4 will probably work its way into the 6th gen eventually.
FenwickHockey65's GM Thread!
2003 GMC Envoy SLE - Airaid Cold Air Intake, Gibson Performance Catback Exhaust
2007 Ford F-150 (State-issued)
Old 02-18-2013, 11:15 AM   #21
90503
Ok...I'll bite...What the heck is an LT4?...lol...(sorry...lol)...(the short version will do)...lol
Old 02-18-2013, 11:19 AM   #22
FenwickHockey65
Well let's just say the Gen V V8 is very friendly with forced induction.
Old 02-18-2013, 11:54 AM   #23
GretchenGotGrowl
I think the rumors about the LS7 are more for the final year(s) of the 5th Gen. I think (read hope) the LS7 will have it's swan song with the Camaro, but I'm pretty sure its on the way out.
I don't really know what to expect with the LS3. I don't think it will go away immediately, but GM is going the migrate everything over to the Gen V motors at some point. We will probably see the LS3 and L99 through the rest of the 5th Gen Camaro runs. We may see the L99 popup in some other platforms before it is retired. It's all really hard to guess, but we know ultimately GM will replace the Gen IV motors with the Gen V motors.
Build Thread
Old 02-18-2013, 12:31 PM   #24
KMPrenger
KMPrenger's Avatar
We've touched on this subject before, and I have to say I don't doubt that at all.
The V6 DI engines are capable of making some pretty impressive power figures with just 6 - 8 psi of boost. (450+ HP at the crank) But past that amount of boost, we typically see fuel issues where the stock pump can't keep up.
That same small amount of boost on a modern V8 DI engine should be super impressive.
Old 02-18-2013, 01:14 PM   #25
GretchenGotGrowl
Yeah, these mechanical High-Pressure Fuel Pumps are a PITA. Too big and they flow too much fuel at idle and low RPMs. Too small and they don't flow enough at the high RPMs. It would be nice if they had two, one that had a valve that didn't open to the fuel rails until the RPMs were above 4000, otherwise it just recirculates the fuel. I think that would solve the problem for high HP demands.
Build Thread
2015 camaro, 2015 camaro forum, 2015 camaro forums, 2015 chevrolet camaro, 2015 chevy camaro, 2016 camaro, 2016 camaro forum, 2016 camaro forums, 2016 chevrolet camaro, 2016 chevy camaro, 2017 camaro, 2017 chevy camaro, 6 gen camaro, 6th gen camaro, 6th gen camaro forum, 6th gen camaro forums, 6th gen camaro info, 6th gen camaro news, 6th gen camaro rumors, 6th gen chevrolet camaro, 6th gen chevy camaro, 6th gen chevy camaro forum, 6th generation camaro, 6th generation camaro info, 6th generation camaro news, 6th generation camaro rumors, 6th generation chevy camaro, camaro 6th gen, camaro 6th generation
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
