Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
B&M Racing
Old 12-31-2012, 10:11 AM   #57
Richy_Rich
FAVOR
Richy_Rich's Avatar
Drives: Many Different Rides
"gloss piano black" option for replacing silver bits.
Please be kind when you drive; thank you.
Richy_Rich is offline   Reply With Quote
Old 01-02-2013, 03:41 PM   #58
v8
v8's Avatar
Drives: GT500 and 14 ZL1
Originally Posted by v8 View Post
lose 300-400lbs:
manufacture the front suspension(control arms) out of something lighter than the current steel (maybe aluminum)
carbon fiber/aluminum drive shaft
I know that wont lose all the weight but its a start
LT1 direct injection engine for the SS
thicker clear coat to reduce chips
I forgot to add:
Custom steering wheel
Gone but not forgotten:
1974 Corvette Stingray 454
1986 Z28
2009 Mustang GT convertible
2012 45th 2SS Vert
2013 ZL1 M6
v8 is offline   Reply With Quote
Old 01-02-2013, 03:51 PM   #59
akCamaross
akCamaross's Avatar
Drives: 2011 Camaro 2SS
Bring back 2010-2011 steering wheel. And make a noticeable difference from the ls lt rs ss zl1.
2011 Camaro 2SS - SIM - M6 + Mods haha
akCamaross is offline   Reply With Quote
Old 01-11-2013, 02:34 PM   #60
Richy_Rich
FAVOR
Richy_Rich's Avatar
Move it to ATS chassis, add the LT1 engine program and mix in some Gen1/2 styling.
My Wish List:
- Gen 6 ATS Camaro, SS - new Gen 7 Corvette LT1 V8 (450HP).
- Gen 6 ATS Camaro, 1LE (handling pak) - new Gen 7 Corvette LT1 V8 (450HP).
- Gen 6 ATS Z/28, whatever Gen 7 Vette Z06 LT was available (530HP)
- Gen 6 ZL1, whatever Gen 7 Corvette ZR-1 SC LT program was offered should go here (680hp)
Old 01-11-2013, 08:07 PM   #61
Bhobbs
Bhobbs's Avatar
Make available with everything but a driver seat, gas, brake, clutch and steering wheel as a optional delete.
Bhobbs is online now   Reply With Quote
Old 01-12-2013, 10:23 AM   #62
attymf
attymf's Avatar
Drives: 2017 SS
Instead of gas it shoud run on water. Speaking of water, it should be able to go under water in submarine mode.
SS, A8, Procharger, M&T's and stuff...
attymf is offline   Reply With Quote
Old 01-13-2013, 08:08 PM   #63
mr02Z/28
Drives: 2002 Z/28,1968 Chevelle convert.
6th Gen
- 3,400lbs
- 3.73 gears(posi on all models)
- a if a 4 banger is going to be the base, it should be around 320-325hp
- a Twin Turbo V-6 as option
- a V-8 on the SS and Z/28
mr02Z/28 is offline   Reply With Quote
Old 01-14-2013, 04:37 AM   #64
Iroc2430
Smoke'm if you can
Iroc2430's Avatar
Drives: 2010 Camaro 2SS/RS/LS3/M6
Heated Steering Wheel
Texas Speed LT Headers with HF Cats, Borla ATAK Exhaust, MGW Short Throw Shifter, ADM CAI with Scoop, Elite Oil Catch Can, Mishimoto Aluminum Radiator, Pedders XA Coilovers, Mantic Twin 9000 Clutch, PFADT Solid Subframe Bushings, PFADT Front & Rear Sways, PFADT Upper Control Arm Bushing, PFADT Trailing Arms/Tie Rods, Whiteline Adjustable End Links, Whiteline Adjustable Lower Control Arms, Pedders Diff Bushings, Line Lock, ACC Side Markers, ACC Reverse Lights, Custom Tune from Nitrous Express.
Iroc2430 is offline   Reply With Quote
Old 01-14-2013, 09:49 AM   #65
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 10 Legacy 2.5GT, ...
I like how you think.
I'd insist on the continued availability of at least 1LE-level chassis specs, but stop short of ZL1 dampers (unless the damping programming offered multiple choice and/or user tweaks).
Norm
Old 01-14-2013, 03:42 PM   #66
meissen
Founder - Michigan FBody
meissen's Avatar
Drives: 1994 Camaro LT1, 2016 Camaro LT
I wish it'd have t-tops but alas I know that's not a possibility anymore... :( :( :( :(
2016 Camaro 1LT V6 A8 - "Elmo" - LGX V6 with 8-Speed Automatic, NPP Dual Mode Exhaust
1994 Camaro LT1 A4 - "Red Alert" - v6-to-LT1 Swapped Cruiser; Cammed, Stalled, Enjoyed
"Gone But Not Forgotten"
2014 Camaro 1LT M6 - "Cherry Bomb"
2012 Camaro 1LS M6 - "Clifford"
Michigan FBody Association
http://www.mifbody.com/
meissen is offline   Reply With Quote
Old 01-19-2013, 07:08 AM   #67
AdamZ
Drives: Eve - 2011 Camaro 2SS/RS
Originally Posted by karguy View Post
The current car has to many practical diusadvantages due to the slightly cartoonish design that unfortunately is not as clean as the origional.
I hope those mistakes won't be repeated !
How does my Camaro look like a cartoon
I also hope the new one will also get a practical hatchback with a useful trunk.
Dafuq you need a trunk for. Just need enough room for nitrous
AdamZ is offline   Reply With Quote
Old 01-19-2013, 07:15 AM   #68
pocketcthulhu
pocketcthulhu's Avatar
Drives: 2014 2ss/RS 5th gen Camaro #2
it's large enough to stuff a couple of bodies into what else do you need?
I MEAN BAGS why would you put bodies in the trunk i mean really
pocketcthulhu is offline   Reply With Quote
Old 01-19-2013, 12:19 PM   #69
KMPrenger
KMPrenger's Avatar
I don't really understand the "cartoonish" comments about the Camaro. It looks almost exactly like the concept Camaro, which was a jaw dropping design at the time, and still turns heads even today. Not trying to be an A-hole here, but sorry if your not into it, you are clearly in the minority.
I wouldn't mind a little better visibility, but the high beltline is one of the reasons the car looks so damn good. If that was lowered, it would look awkward. GM, do what you must to make the next design just as killer as this one.
Make the car lighter, and feel more nimble out on the road, and you have a winner. If the current car had those traits, it would still be top dog in the performance categories.
Old 01-19-2013, 12:38 PM   #70
motorhead
motorhead's Avatar
Not asking for much are we.
motorhead is online now   Reply With Quote
2015 camaro, 2015 camaro forum, 2015 camaro forums, 2015 chevrolet camaro, 2015 chevy camaro, 2016 camaro, 2016 camaro forum, 2016 camaro forums, 2016 chevrolet camaro, 2016 chevy camaro, 2017 camaro, 2017 chevy camaro, 6 gen camaro, 6th gen camaro, 6th gen camaro forum, 6th gen camaro forums, 6th gen camaro info, 6th gen camaro news, 6th gen camaro rumors, 6th gen chevrolet camaro, 6th gen chevy camaro, 6th gen chevy camaro forum, 6th generation camaro, 6th generation camaro info, 6th generation camaro news, 6th generation camaro rumors, 6th generation chevy camaro, camaro 6th gen, camaro 6th generation
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
