Old 10-01-2015, 06:06 PM   #1
ajohnson
Drives: 2010 Camaro 1LT
Courtesy light question..
Hello all, new to the forum and have been trying to do some research but have a lot of questions to ask and hope y'all don't mind. Just recently purchased a 2010 lt, None of the interior lights works, dome lights, flooring lights, etc. I have a key fob and upon unlocking doors no lights turn on inside whatsoever, tried messing with the dimmer and the actual physical dome switch and nothing at all. Thought maybe it was a BCM fuse, nada. Any ideas? Thinking it may be the actual BCM itself? to say the least, im 99% certain when i test drove it earlier this week they worked. Going back to the dealer to have them inspect it on monday but figured id ask on here for some input or suggestions... thanks!
ajohnson is offline   Reply With Quote
Old 10-01-2015, 06:51 PM   #2
MBS
MBS's Avatar
Drives: 2010 rs 2lt
Yah sounds like a fuse blew ? I would look in your owners manual to determine which fuse to pull to look at
MBS is offline   Reply With Quote
Old 10-01-2015, 08:02 PM   #3
ajohnson
I checked all the fuses linking to the bcm just to be sure and not were blown.. Its dark out now but from what i read online and checked everywhere there isnt a specific fuse related to the courtesy (interior) lights..
Old 10-01-2015, 08:04 PM   #4
Spec
Drives: 2010 Camaro 1SS LS3
Yep... sounds like a fuse. The next question would by why did it blow? Or is it just missing? Did someone use tin foil or something?
The fuse box has many ports that are not used. Here's some assistance (images below);
ENGINE COMPARTMENT FUSE BLOCK
[IMG]http://*************/forum/images/enginecompfuseblock.jpeg[/IMG]
To remove the hinged fuse block cover, press the clip at the front of the cover, and swing it up.
Notice: Spilling liquid on any electrical components on the vehicle may damage it. Always keep the covers on any electrical component.
[IMG]http://*************/forum/images/enginecompfuses.jpeg[/IMG]
J-Case Fuses Usage
Fuse 6 Wiper
Fuse 12 Starter
Fuse 22 Brake Vacuum Pump
Fuse 25 Power Windows Rear
Fuse 26 Power Windows Front
Fuse 27 Rear Defog
Fuse 41 Cooling Fan High
Fuse 42 Front Heater, Ventilation and Air Conditioning
Fuse 43 Antilock Brake System Pump
Fuse 44 Cooling Fan Low
Mini Fuses Usage
Fuse 1 Air Conditioning Compressor Clutch
Fuse 2 Transmission Control Module
Fuse 5 Engine Control Module Main
Fuse 7 Pre-Catalytic Converter Oxygen Sensor
Fuse 8 Post-Catalytic Converter Oxygen Sensor
Fuse 9 Fuel Injectors - Even
Fuse 10 Fuel Injectors - Odd
Fuse 11 Cooling Fan Relay
Fuse 14 Manifold Air Flow/Chassis Control
Fuse 15 Ignition
Fuse 16 Run/Crank IP
Fuse 17 Sensing Diagnostic Module/Ignition
Fuse 18 Run/Crank Body
Fuse 19 Transmission Control Module/Ignition
Fuse 20 Engine Control Module/Ignition
Fuse 31 Outside Rear View Mirror
Fuse 32 Canister Vent Solenoid
Fuse 33 Body Control Module #6
Fuse 34 Sunroof
Fuse 35 Front Heated Seats
Fuse 38 Washer Pump Front
Fuse 40 Antilock Brake System Valves
Fuse 46 HID Headlamp - Left Front
Fuse 47 HID Headlamp - Right Front
Fuse 50 Fog Lamps
Fuse 51 Horn
Fuse 52 Spare
Fuse 55 High Beam Headlamp - Right Front
Fuse 56 High Beam Headlamp -Left Front
Fuse 61 Heated Mirror
Mini Relays Usage
Relay K26 Powertrain
Relay K50 Run / Crank
Relay K55 Rear Defog
Relay K612 Cooling Fan High
Relay K614 Cooling Fan Control
Micro Relays Usage
Relay K61 Starter
Relay K69 Wiper Control
Relay K613 Cooling Fan Low
Relay K617 Air Conditioning Compressor Clutch
Relay K619 Wiper Speed
Relay K627 High Intensity Discharge Headlamps
Relay K632 Brake Vacuum Pump
"Compliments of Alldata"
http://www.*************/forum/viewtopic.php?f=21&t=564
Good luck... and ultimately hope its nothing serious.
Spec is offline   Reply With Quote
Old 10-01-2015, 08:06 PM   #5
ajohnson
See thats what i mean though, none of the fuses that i could see would link to the interior lights so thats why im so puzzled..
Old 10-01-2015, 08:10 PM   #6
Spec
Hmm... you're right, and none of those are specific to interior lighting. I'm out of ideas... sorry couldn't help. Again, good luck and hope its nothing serious.
Old 10-01-2015, 08:13 PM   #7
Aug
Drives: 2014 2SS MT, Convertible
I believe these are controlled by the BPM. Are there any other systems in the car not functioning properly that could be BPM related?
Steve
Saint Augustine FL
Aug is offline   Reply With Quote
Old 10-01-2015, 08:25 PM   #8
sdynak
Drives: 2010 1SS
Any chance it is a 2SS with ambient lighting and is just dimmed to where it does not come on?
Edit - I see you tried that.. nevermind
2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
sdynak is offline   Reply With Quote
Old 10-01-2015, 08:28 PM   #9
Quicksilver-SS
Quicksilver-SS's Avatar
Drives: 2014 1SS / RS M6
Have you checked the position if the overhead switch??
Quicksilver-SS is offline   Reply With Quote
Old 10-01-2015, 09:56 PM   #10
Xello
Xello's Avatar
Drives: 2010 CGM 2SS/RS
Did you actually open the door?
Xello is offline   Reply With Quote
Old 10-01-2015, 10:01 PM   #11
Kghops119
Drives: 11 2SS VERT, 10 VETTE GSSC, 15 Z/28
Is it plugged in?
Kghops119 is offline   Reply With Quote
Old 10-02-2015, 06:51 AM   #12
xnuyokr
xnuyokr's Avatar
Drives: 2012 1LT Drop Top
Unless it was added you don't have footwell lighting, maybe you just have a bad bulb in the dome light!
xnuyokr is offline   Reply With Quote
Old 10-02-2015, 07:05 AM   #13
CamaroinCLE
CamaroinCLE's Avatar
Drives: 2014 CRT LT
when in doubt "reboot" the car. Works for PC's all the time.
CamaroinCLE is offline   Reply With Quote
Old 10-02-2015, 10:43 AM   #14
yzark99
I run 2 catch cans...
yzark99's Avatar
Drives: 2012 1LT SIM Auto
Have you checked all 3 fuseboxes? There is one in the trunk on the passenger side, and one in the cabin behind the driver's side of the dash (pull off side cover). Is there a setting in the radio for these lights? One bad bulb can also hose the circuit.
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Laminator FX + Extendolator • SOLO Hi-Flo Cats + Cat-Back Exhaust
View my top 3 LFX performance mods and more:
yzark99 is offline   Reply With Quote
