11-22-2016, 11:42 PM | #1 |
Drives: '18 SS 1LE Join Date: Jul 2016
Backpressure?
I've been planning on ordering some long tube headers for a while, been comparing different brands and prices. I really like Speed Engineering headers.
I've been talking to my father about my plans, He's built 3 '68-'70 Chevelle's and many other GM vehicles, mainly older. He says long tube headers are not worth it, because they reduce the backpressure in your exhaust system, which is responsible for your low end RPM HP. He says i shouldn't buy headers until i've worked on the bottom end more, because I will lose power with headers. How true is this? I know he knows what he is talking about. But... are headers not worth the money because they reduce backpressure in the exhaust? How important is this? I respect my father a lot, please don't flame. Any decent feedback on this would be really appreciated. Thanks C5! |
11-23-2016, 01:39 AM | #2 |
USA-1
With all respect due to your father....he's dead wrong. With a decent tune longtube headers will increase power by about 20-30 rear-wheel horsepower and are well worth the $350 (assuming you go with Speed Engineering) you'll spend on them.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
11-23-2016, 01:53 AM | #3 |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
That's one of those "old school" myths that's been debunked, you will pick up hp/tq all over the place especially midrange and up top. Just search for long tube headers dyno sheets there are thousands showing the gains in power
11-23-2016, 01:55 AM | #4 |
Drives: 2014 2SS/RS Join Date: Jun 2013
Back pressure is negligible in comparison to just having a bigger pipe.
Theres no comparison between LT and stock manifolds or shorties. For the cat-back to the axles, the rest is weight savings and exhaust sound preference. Unless youre pushing some big power and need a bigger pipe. |
11-23-2016, 06:26 AM | #5 |
Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
"The proof is in the pudding", old quote but, still true. LT headers with a good cat back system have increased the power for just about everyone on this site. The system I have, turned my SS into the animal I always wanted.
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, AWE Touring, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
11-23-2016, 10:59 AM | #6 | |
Drives: 2018 1SS M6 Join Date: Nov 2014
Your dad isn't completely wrong. He's just got the terminology incorrect. what he's talking about that increases torque and thus power are the concepts of scavenging and vacuum pulse tuning.
11-23-2016, 12:23 PM | #7 |
Drives: 2014 2SS/RS/1LE Join Date: Mar 2015
I agree. This has been proven numerous times.
11-23-2016, 12:44 PM | #8 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
Keep in mind his Dad is referring to LOW END hp (if that makes any difference).
11-23-2016, 01:09 PM | #9 |
Its nice when someone gets it. I have used tri-Y forms of headers for a long time, for some of these reasons. Scavenging or in other words, creating a low pressure just at the tube end, at the right time, is what headers are all about. Just having a header but not one designed for the your goal is nothing but eye candy. Tube length, tube diameter, collector design, diameter and length are all some of the things you should be looking for. Most of the name brand aftermarket headers have this engineered in their design for you.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears. |
11-23-2016, 01:50 PM | #10 |
Design only matters when you're stuck with one available pipe size. Every dyno chart shows LT headers losing nothing, but also gaining nothing on the bottom end. And I'm talking like under 2k
Can we not try to justify our bad purchases to make ourselves feel better? I've made some mistakes myself and I'm willing to admit it |
11-23-2016, 02:06 PM | #11 |
I think you've received some good (and respectful) responses regarding you dad's theory on headers. There is nothing I can add other than to say these modern V8 engines in our Camaros LOVE long-tubes in combination with a good custom tune. I haven't dyno'd my SS before or after adding mine, but my BUTT DYNO says the gains are significant.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
11-23-2016, 02:30 PM | #12 |
Drives: Black L99 2SS/RS Join Date: Mar 2014
Dyno and hp blah blah blah... who cares what numbers on a computer say.
http://www.camaro5.com/forums/showthread.php?t=21013 The official 1/4 mile say that just with long tube headers, cold air intake and a ported throttle body have actually made our Camaro's almost two seconds faster at the track (where is actually counts). |
11-23-2016, 03:28 PM | #13 |
My dad told me the same thing about putting headers on my car haha. Like others have said, the proof is all over this site, they do increase numbers.
Sent from my Pixel using Tapatalk
12.3 @113MPH - Full Bolt-Ons w/ Nitto 555r on 18" wheel
11-23-2016, 03:44 PM | #14 |
Drives: 2011 2SS/RS M6 Join Date: Oct 2015
I think the backpressure myth came about because when a carbureted engine had headers put on it they didn't tune the carb to account for the change. Fuel injected cars simply adjust to compensate for any change. The trusty ol butt dyno felt a little sag when the stepped on it and the only change they made was to the exhaust, so it had to be that, right?
