TireRack
Old 08-24-2013, 12:19 AM   #1
Bmatth1162
Bmatth1162's Avatar
Drives: 2011 1SS/RS LS3
How is top speed reached in 5th gear? (LS3)
I forget exactly how it came up, but I was talking with my friend today and he mentioned how he thought it was funny that the top speed in our cars is reached in 5th gear, but can't be reached in 6th. I just sort of nodded and hoped he couldn't read my mind (pure confusion). Is this even true? Intuitively, the top gear would be the one to reach the top speed, but maybe the ratio in 6th is so low that it can't functionally use the HP needed to get there? That's my only confused explanation. Thanks!
CAI intake, apex scoop, Vmax ported TB, MGW short throw, BMR 1" springs and sways
Bmatth1162 is offline   Reply With Quote
Old 08-24-2013, 12:52 AM   #2
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
dont know but you reach the 155mph speed limiter right after shifting into 5th
Old 08-24-2013, 01:34 AM   #3
Biscuitpie
Biscuitpie's Avatar
Drives: '11 Cammed LS3, '14 Scion FRS
Granny shifting! You can hit 160 in 4th. Source: internet and personal experience. I think 6th mathematically goes to 288 or something so you'll never hit that speed. Not sure what 5th goes to but it's lower than 6th.
SOLD with a Z06 in the not too distant future: Cammed, boltons, axles, lowered, and more. | 476 WHP
Biscuitpie is offline   Reply With Quote
Old 08-24-2013, 01:34 AM   #4
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
In the absence of speed limiters and the spectre of death, the top speed of a Camaro would be reached at a point that enables the engine to be delivering maximum power at the lowest gear ratio to overcome aerodynamic and friction losses.
Have fun.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 08-24-2013, 05:13 AM   #5
jd10013
Drives: 2012 camaro
6th is an overdrive designed for MPG's. you probably would loose a bit of power going from 5th to 6th
jd10013 is offline   Reply With Quote
Old 08-24-2013, 05:18 AM   #6
zackex
Drives: 45th Camaro SS
I like sixth because it just quiets things down on the highway and that big V8 just lopes along with all the torque. Then you can just shift to fourth to blast out there when you want to.
Audente Fortuna Iuvat
zackex is offline   Reply With Quote
Old 08-24-2013, 06:15 AM   #7
mrvenicess
mrvenicess's Avatar
Drives: 2013 CRT ZL1 auto
Top speed is reached in 5th gear, 178 or there abouts, 6th is too tall and usually tops out around 145.
mrvenicess is offline   Reply With Quote
Old 08-24-2013, 10:31 AM   #8
FaytalsCamaro
Distributor of Liquor
FaytalsCamaro's Avatar
Drives: My Wife Crazy
this...6th gear is overdrive and it doesnt have the power to overcome air resistance to reach topspeed. Moreso meant for MPG. And also like it was said before with the speed limiter at 155 top speed can be reached in 4th
FaytalsCamaro is offline   Reply With Quote
Old 08-24-2013, 02:21 PM   #9
Dupree878
Dupree878's Avatar
Drives: '13 Dusk Edition 2SS/RS M6
Where do y'all get a speed limiter at 155?
Mine's showed 162 before I Had to get out of it. And that was in 5th.
Dupree878 is offline   Reply With Quote
Old 08-24-2013, 02:58 PM   #10
Biscuitpie
Biscuitpie's Avatar
Do you have a tune? In any stock Camaro the DIC/HUD will say "Speed Limiter Reached" or something like that at 155. I could always go 156 for some reason though.
Old 08-24-2013, 04:13 PM   #11
2012-1822
2012-1822's Avatar
Drives: Black ZL1
ZL1's go a little higher before that crap kicks in.
Check out Alabama Camaros, for Camaro enthusiasts all around Alabama https://www.facebook.com/groups/1739...group_activity
2012-1822 is offline   Reply With Quote
Old 08-24-2013, 04:30 PM   #12
Emvici
Drives: 2014 ZL1 White Convertible
will a dyno tune allow you to bypass the speed limiter?
Emvici is offline   Reply With Quote
Old 08-24-2013, 04:33 PM   #13
Biscuitpie
Biscuitpie's Avatar
Yep, so will a handheld.
Old 08-24-2013, 04:44 PM   #14
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
You guys realize that 5th is also an overdrive gear, right?
SUX2BU is offline   Reply With Quote
