10-09-2016, 10:01 AM | #1 |
Drives: 2013 Camaro ZL1 Join Date: Jul 2013
Boost gague not working.
Anyone else had issues with their boost gauge not working? during start up it will sweep like all the other gauges but then remains at the 12:00 position.
ported snout on the supercharger, ADM coupler, 2.38" blower pulley, 85LB injectors, 160 thermostat, upgraded spark plugs, Roto-Fab CAI, BTR stage 3 cam and springs, Kooks long tube headers, CAT delete, ADM heat exchanger, KenneBell boost-a-pump, MGW short throw shifter.
10-13-2016, 11:03 PM | #2 |
Drives: 2013 Camaro ZL1 Victory Red A6 Join Date: Aug 2013
I had that issue after my motor was rebuilt. If you also don't have boost, it may be same thing. I had bad MAP sensor. the one on the front driver's side corner of the SC.
