Old 01-13-2014, 11:46 AM   #127
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
Working on some variations.
This one is a slight variation of what I've already been working on.
Name:  2020 Concept altJa.jpg
This one is new; a more organic styling where I've smoothed things out all over the place on the top half of the car, and widened the cabin out to the body edge.
Name:  2020 Concept altK.jpg
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 01-13-2014, 01:19 PM   #128
ssrs396
ssrs396's Avatar
Drives: 68 vert 396 13 ls
Hmmm......I like the first one better. But even with the second one I wonder if you could raise the fender lines or lower the hood to give the fender some character. The one thing I have always liked about my 68 is the top fender line especially driving. I don't know if it would work with your design. Maybe something like they did with the new corvette. Vettes have always had raised fenders but with the new one they have lowered the overall hood area to get the same effect. Looks great.
ssrs396 is offline   Reply With Quote
Old 01-13-2014, 07:14 PM   #129
Doc
Doc's Avatar
I've done a more traditional version and tried to keep the front fender line low but this is really starting to look like a 69' Camaro body style.
Name:  2020 Concept alt10K1.jpg
Name:  2020 Concept alt10K2.jpg
Name:  2020 Concept alt10K3.jpg
1SS/RS LS3 M6 IBM
Old 01-13-2014, 09:10 PM   #130
oldfriend
Drives: Fiat 500 E
I can see where this is going .
But I still would have tried to bring the B pilar at least half way out to the fender line , if not 75%
Just a thing that I have in mind looks wise
oldfriend is offline   Reply With Quote
Old 01-15-2014, 02:35 AM   #131
Doc
Doc's Avatar
Here's a version based more or less on the 1967 Camaro which was always one of my favorites. It's a modern interpretation but it has promise. I still need to do some work on the lower half of the car but overall it's got an interesting look.
Since I KNOW somebody is going to try and claim it looks like a Fiero... it doesn't so don't be "that guy" and post that.
Name:  2020 Concept alt11a.jpg
Name:  2020 Concept alt11b.jpg
Name:  2020 Concept alt11c.jpg
It also works pretty well as a 1LE:
Name:  2020 Concept alt11d.jpg
Name:  2020 Concept alt11e.jpg
Name:  2020 Concept alt11f.jpg
If you like it great; describe what you like if you can. If you don't like it; describe what features you don't like and why; don't tell me what old car you think it looks like because I don't care about that. What I want to find out is what do you like or don't like about the styling features.
1SS/RS LS3 M6 IBM
Old 01-15-2014, 09:07 PM   #132
ssrs396
ssrs396's Avatar
I like that last profile shot. It almost looks like it could be an import fighter with a screaming turbo 4 in it. I know that is not what you are going for but it would work.
I tried to give the upper fender some definition, I still like these lights the best.
Old 01-15-2014, 09:26 PM   #133
oldfriend
Drives: Fiat 500 E
Attachment 590863
Attachment 590864
Attachment 590865
Attachment 590866
Attachment 590867
Attachment 590868
I like the front , but , to me I would try to locate the lower light all the way to the far out of the grill , just like the headlights above .
And maybe make it the same shape as the grill they are in
Old 01-15-2014, 09:34 PM   #134
Todd in Vancouver
Todd in Vancouver's Avatar
Drives: 2014 ZL1
I'm liking this version above now without the side indent like on the earlier ones. It's a bit to much of a wedge shape. Look at the distance from the rear wheel to the top of the fender. Now do the same on the front and there is to much of a difference. Increase the front and decrease the rear and it should have a bit more symmetry.
Todd in Vancouver
'14 ZL1 Camaro
'67 Camaro SS Pro-tour in process
How hard can it be...
Check out my other build http://www.pro-touring.com/threads/9...ject-Obsession
Todd in Vancouver is offline   Reply With Quote
Old 01-15-2014, 09:43 PM   #135
oldfriend
Drives: Fiat 500 E
Well , the way it is , it gives the impression that's moving forward , even when standing still
The rake like from back to front to me is just right
If one moves that line to a more level one , you loose that effect , and makes the car look like boxy , and that's something one tries not to do
But again it won't hurt to try
Old 01-16-2014, 03:18 AM   #136
Doc
Doc's Avatar
It would be possible to do those lights for this design. I'll look into that but that takes it out of the modern 67' Camaro styling, which may not be an issue if it looks good.
Like this?
Name:  2020 Concept alt11a2.jpg
I've raised the front fender line a bit but it definitely weakens the fighter jet profile look. Normally I'm all for symmetry but in this particular case I think the more aggressive fighter jet look actually works better. I'll try something in the middle and see how that looks.
Name:  2020 Concept alt11a4.jpg
Name:  2020 Concept alt11a3.jpg
1SS/RS LS3 M6 IBM
Old 01-17-2014, 12:39 AM   #137
Doc
Doc's Avatar
Did some more finishing work on details. Lowered the front fender line just a tad; between where it was originally and the previous adjustment.
Name:  2020 Concept alt11b2.jpg
Name:  2020 Concept alt11b3.jpg
Name:  2020 Concept alt11b4.jpg
Although from low angles it may appear there isn't hardly any curve in the front fender line, in reality there's actually quite a bit.
Name:  2020 Concept alt11b1.jpg
1SS/RS LS3 M6 IBM
Old 01-17-2014, 07:44 AM   #138
oldfriend
Drives: Fiat 500 E
I like the front the way you did , but still not feeling that bright line ( light ) just below the headlights
On the back , you managed to put the turn signal wrapping around the corner , that was the look that I was going for at the front also
The trunk lid looks like could be made wider , so we can have easier access to the trunk , that way you may have to turn the B pillar a little more to the outside
The tail pipes in my opinion needs to have a better more modern look/location
Thanks for your time around here
Old 01-17-2014, 08:24 AM   #139
CLOTAGAMES
CLOTAGAMES's Avatar
Drives: 2014 VERT SS/RS
how about a retractable hardtop?
CLOTAGAMES is offline   Reply With Quote
Old 01-18-2014, 01:51 AM   #140
Doc
Doc's Avatar
"Bright line" was an LED strip but I took it out so you could see the difference. I tried the cut-through on the front corners but it totally did not work with this style. I may remove it from the back and see what it looks like without it there too. The trunk width would depend on the construction under the skin. It could probably be made wider although the rear wheel wells are in those areas. Not sure what you mean by "more modern look/location" for the tail pipes. Do you have some examples of what you have in mind?
Soft and/or retractable hard tops seem to be such a reliability issue. That would be something the Chevy engineers would have to decide on. How to make that work with crash/rollover safety requirements is something I have no idea what would need to be done.
Here are snapshots of the current refinements. Did some styling work on the front grill/headlights area mostly so it didn't look quite so plain, and of course the LED bar under the headlights is gone.
Name:  2020 Concept alt11c1.jpg
Name:  2020 Concept alt11c2.jpg
Name:  2020 Concept alt11c3.jpg
1SS/RS LS3 M6 IBM
2016 camaro, 2016 camaro forum, 2016 camaro forums, 2016 chevrolet camaro, 2016 chevy camaro, 2017 camaro, 2017 chevy camaro, 6 gen camaro, 6th gen camaro, 6th gen camaro forum, 6th gen camaro forums, 6th gen camaro info, 6th gen camaro news, 6th gen camaro rumors, 6th gen chevrolet camaro, 6th gen chevy camaro, 6th gen chevy camaro forum, 6th generation camaro, 6th generation camaro info, 6th generation camaro news, 6th generation camaro rumors, 6th generation chevy camaro, camaro 6th gen, camaro 6th generation
