05-21-2015, 08:59 PM | #15 | |
Drives: 2016 F150 Join Date: May 2014
Darn it. Could have sworn the v6 Accord is rated at 34. Lol. |
05-21-2015, 09:09 PM | #16 |
05-21-2015, 09:13 PM | #17 |
Drives: Really Slow Join Date: Apr 2010
where the heck do you get that information? putting the car in neutral is like just sitting in your car with the car at idle. You are using very little gas. whereas in an automatic, when in gear, the rpms fall slower and uses more gas. In a manual, right when you push the clutch in to put in neutral, your rpms fall down to idle speed almost immediately.
05-21-2015, 09:20 PM | #18 |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
In the calibration of many cars today, fuel shuts off when coasting. The aggressiveness of this depends on how much fuel economy the OEM is striving to get. Aggressive fuel shut off can lead to drivability issues, but for the most part people don't notice the difference. Only picky drivers.
05-21-2015, 09:22 PM | #19 | |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
05-21-2015, 09:29 PM | #20 |
I've only really driven manual. so I did not know that in automatics that coasting down in gear shuts the fuel off.
05-21-2015, 09:36 PM | #21 |
It's typically a similar strategy on manuals. If you coast down in gear, fueling will go to 0 (depending on extent of the motoring condition).
05-21-2015, 09:42 PM | #22 | |
so if that is what you guys are talking about, I call BS. unless the engine actually cuts off fuel when coasting down, then the engine is still consuming fuel more-so in the automatic because it's slower to reach idle speed than a manual in neutral.
05-21-2015, 09:44 PM | #23 |
Take any existing car. Add AFM 1 to 1.5 mpg. Add 8 speed vs. 6 speed add 1 mpg. So assuming they do the same aggressive MPG calibrations and contenting, the LS (ooops there isn't one) would get 32.5 to 33 mpg.
So the even bigger question is can a 2.0T that gets 31 in the ATS actually deliver 35 to 36 in the Camaro? Maybe it can with the 8 speed. But if the 2.0T can't get at least 3 mpg highway better than the V6 it has no real mission in life other than fewer cylinders.
05-21-2015, 09:45 PM | #24 |
36.58625, -121.7568
05-21-2015, 09:46 PM | #25 | |
05-21-2015, 09:47 PM | #26 | |
05-21-2015, 09:48 PM | #27 |
05-21-2015, 09:48 PM | #28 |
Also don't forget neutral idle. Car shifts into neutral when brake is applied and car is stopped for more than 1 second.
