dave@hennessey
Old 10-07-2009, 10:32 AM   #1
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Suspension guys out there - lets talk wheel hop
My track experience was definately dampened by LOTs of wheelhop all through 1st and 2nd gear. This was with stock tires at stock pressure. Lets talk about practical ways to remove wheel hop. (NOTE: on the street, the tires are free to spin and there really isn't any hop).
Thanks,
Crowley
Crowley is offline   Reply With Quote
Old 10-07-2009, 11:04 AM   #2
vsgls1
vsgls1's Avatar
Drives: 07 GMC Sierra
Send a message via AIM to vsgls1
This should help.
http://www.camaro5.com/forums/showthread.php?t=41731
Keith 2SS/RS MN6 in CGM. Delivered 6/22/09. Blown 7/29/09. Sold 12/6/10.
07 GMC Sierra
vsgls1 is offline   Reply With Quote
Old 10-07-2009, 11:18 AM   #3
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Originally Posted by vsgls1 View Post
Thanks .. I saw this but was looking for additional input. Im currious if anyone has tried the items in your link and if they work.
Crowley
Old 10-07-2009, 11:22 AM   #4
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2011 2SS/RS/A6 cammed-n-whippled
the BMR bars should help a lot with weight transfer (to the rear)...I'm pretty sure someone posted there w/boost and had good results. Those and some drag-radials should make it launch much better.
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 10-07-2009, 11:25 AM   #5
cheaplabor
It the toybox 4 winter
cheaplabor's Avatar
Drives: LSA 68f100 pickup/2010 rs/2ss abm
i noticed this also, my cousin has a cts-v and he replaced the bushings on the diff carrier/suspension mount with poly bushings and said that it was almost gone. then replaced one axle shaft with a larger one (cannot remember which side) and it is gone completely now. since it uses the same susp that would probably solve our problems too
cheaplabor is offline   Reply With Quote
Old 10-07-2009, 11:31 AM   #6
lawdogg149
lawdogg149's Avatar
Drives: Corvette ZO6 CSR edition #47
I use the BMR on my 2010 camaro turbo charged car and wheel hop is gone. $139 and 30 mins problem solved.
lawdogg149 is offline   Reply With Quote
Old 10-07-2009, 11:44 AM   #7
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Good to know my friend ... I see this in my future
Old 10-07-2009, 11:50 AM   #8
IPS Brandon
IPS Brandon's Avatar
Drives: 2010 Camaro SS black
Send a message via AIM to IPS Brandon
The trailing arms from BMR will help certainly http://www.ipsmotorsports.net/produc...oducts_id=3655, and then bushings, Subframe bushings from pfadt which will release soon, and control arm bushings will yield much less hop, and transmit more power through the rear end.
Regards
IPS Brandon is offline   Reply With Quote
Old 10-08-2009, 10:00 AM   #9
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Our trailing arms will take care most the wheel hop the car is having. There is many guys out there using them with tons of success. We will also have our new line of bushings out in the next few weeks which will also help. First things first get a set of our trailing arms and go from there.
Old 10-08-2009, 11:25 AM   #10
1BadaSS
Drives: 2010 CGM 2SS 6spd
I just ordered my BMR trailing arms from IPS and my car should be done by in the next few days. I will install the trailing arms and share the results. I'm confident that they will do their job!
2010 CGM 2SS/6MT-Kooks LT headers w/cats, MBRP Exhaust, D1-SC Procharger, FAST 65lb Injectors, NGK TR-6 plugs, 160* T-stat, ADM Boost Gauge,ChuckTuned= 530rwhp/500rwtq
1BadaSS is offline   Reply With Quote
Old 10-08-2009, 12:00 PM   #11
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Definitely let us know how they work for you.
Old 10-08-2009, 12:31 PM   #12
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Pfadt Race Engineering Control Arms
We're working on a Rear Trailing Arm as well as a Rear Tie Rod. They are currently in development and if you're at SEMA you can see them in person! These are the real deal and they weigh less than 50% of the factory unit as well as being over 2x stronger!!!
Rear Carbon Trailing Arm
Rear Carbon Tie Rod
I would highly recommend our Engine Mounts, Trans Mount, sub frame mounts and Differential Bushings as this is where most of your movement is coming from. We've found that the tires load and unload which causes the powertrain to load and unload; the soft mounts just weren't designed to handle this variable. Once this happens the relatively soft spring rate and damping can't control the movement. We've worked with a lot of the fastest C5/C6 Corvettes and this has proven to be a winning combination on those platforms.
We're continually developing new products and they will be worth the wait! Please feel free to call or email us anytime to locate a dealer in your area or with tech/set up questions. Have a great day!
Kind regards,
PfadtRacing is offline   Reply With Quote
Old 10-08-2009, 07:08 PM   #13
KILLER74Z28
MOD SQUAD
KILLER74Z28's Avatar
Drives: 2G1FT1EW9A9100666
Who cares about the Blue Oval crowd and their little Ponys? We're getting our Camaro back-and it'll be Supercharged!-MDAII
Team LS3
KILLER74Z28 is offline   Reply With Quote
Old 10-08-2009, 07:09 PM   #14
KILLER74Z28
MOD SQUAD
Thanks,
Crowley
Glad to see you're looking into this...
Team LS3
2SS Silver Ice Metallic at ATL Car SHow Cmurf_SS Camaro Photos | Spyshots | Video | Media Gallery 40 11-09-2009 09:38 PM
Zeta (Camaro/Commodore/G8) suspension details Gatecrasher Wheels and Tires Talk Sponsored by The Tire Rack 66 04-16-2009 01:11 PM
challenger slow because of wheel hop? What about Camaro? jordan 572 5th Gen Camaro SS LS LT General Discussions 77 02-17-2009 09:23 AM
Bose Suspension... I want CamaroSpike23 Wheels and Tires Talk Sponsored by The Tire Rack 15 03-04-2008 09:38 AM
Independent Rear Suspension a Problem? Warghost Wheels and Tires Talk Sponsored by The Tire Rack 34 06-06-2007 03:02 AM
