Old 04-27-2024, 04:06 AM   #1
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
Front crankshaft seal question.
Is there enough space in the front to replace the front crankshaft seal,
without removing radiator,coolers and bumper ?
-10 L99 engine.
chevy pilot is online now   Reply With Quote
Old 04-28-2024, 06:41 AM   #2
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
I think you might have to take the fans out and I always take the front cover off to do the seal. I'm just not sure about lining up the seal with the front cover on. Another thing you might want to consider is getting an arp bolt for the hormonic balancer so you don't have to mess with the torque to yeld crap on the factory bolt.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 04-28-2024, 07:51 AM   #3
chevy pilot
Thanks.
Btw.Do you mean cover=timing cover ?
So it's worth getting the whole front gasket set.
Old 04-28-2024, 07:57 AM   #4
morepowerjoe
Yes timing cover. And yeah I would get the set. And just in case you don't know there is two bolts that go form the oil pan to the timing cover that are a pain to get to.
Old 04-28-2024, 08:05 AM   #5
chevy pilot
Ok.
Old 04-28-2024, 12:30 PM   #6
bsn
Drives: 2013 ZL1
You can replace just the front seal without removing anything but the harmonic balancer and belts.
bsn is offline   Reply With Quote
Old 04-30-2024, 03:30 AM   #7
Tommi
Tommi's Avatar
Drives: 2010 Camaro SS manual
Yes it can be done. But it can be little difficult to install the new seal properly. In my car the seal had been hammered in too deep, broken a piece from the cover behind the seal. Those liitle aluminium pieces found their way to oil pump, jammed the max pressure regulator piston in open position and I got zero oil pressure.
If I had to do it, I would be extra carful when installing the new seal.
2010 Camaro SS, LS3 + 6spd manual.
1975 Volvo 242, 357SBC + 6 spd manual.
1978 Blazer offroader with LS1, 1-ton axles.
Tommi is offline   Reply With Quote
Old 04-30-2024, 05:08 PM   #8
bsn
Drives: 2013 ZL1
These cars have a ton of room it's not hard at all to replace the front seal, the worst thing is getting the AC belt back on-easy once you get the feel for it. The seal is a simple rubberized press in-it just gets tapped in-if you broke the inner lip you were using way too much force.
Old 05-02-2024, 06:17 AM   #9
Tommi
Tommi's Avatar
I agree, too much force. I dont know who did it. It had oil leak from the seal when i bought the car, planned to fix the seal some day but the day came sooner because the oil pressure issuea.
