Old 03-10-2024, 10:32 PM   #1
Kings2010
Kings2010's Avatar
Drives: 2005 C6, 2013 ZL1 2020 Ram Cummins
AEM AFR wideband not working
I installed the AEM AFR wideband gauge yesterday. The gauge powers on fine. I've rechecked the power and ground.
After engine start the gauge goes full lean and displays dashes. The sensor is heating up. I've checked for exhaust leaks. I even tried holding a gas soaked rag next to the sensor and I can't get it to read anything other then full lean. Are sensor problems out of the box that common? Research seems to suggest the possibility but a lot of the articles are a bit dated.
Has anyone experienced a similar issue recently?
Kings2010 is offline   Reply With Quote
Old 03-11-2024, 12:24 AM   #2
Kings2010
Kings2010's Avatar
I just ordered another sensor. I'll report back
Old 04-05-2024, 08:28 AM   #3
eLeSthree
Drives: 2011 Camaro SS 6sp
Where in the exhaust did you install the 02 sensor?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 04-05-2024, 09:42 AM   #4
The_bald_eagle_machine
Anthony S
The_bald_eagle_machine's Avatar
Drives: 2011 chevrolet camaro 2ss/rs
I had an issue with my wideband AFR guage as well. It would power up and everything but no readings. I bought a ls4.9 sensor off of Amazon because the reviews said that the cheap sensor actually worked really well and tada! It has been working for the last year with no issues. I'm willing to bet that your sensor is just dead.
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181
Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links.
The_bald_eagle_machine is offline   Reply With Quote
Old 04-08-2024, 08:56 PM   #5
Kings2010
Kings2010's Avatar
It's just after the collector in the connection pipe. I welded it in and pressure leak tested it.
I ordered another sensor I just haven't had time to mess with it lately.
Old 04-08-2024, 08:57 PM   #6
Kings2010
Kings2010's Avatar
Good to know. Thanks
