TireRack
Old 06-24-2010, 12:20 PM   #57
ElManny
ElManny's Avatar
Drives: 2010 CGM SS/RS COTW 7/5/2010
Send a message via AIM to ElManny
Originally Posted by JusticePete View Post
How far off center is your steering wheel?
By a bit. 20 degrees. Could that be my problem?
ElManny is offline   Reply With Quote
Old 06-24-2010, 12:35 PM   #58
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Absolutely. The stabilitrak computer thinks you are counter-steering in a skid.
JusticePete is offline   Reply With Quote
Old 06-24-2010, 03:35 PM   #59
ElManny
ElManny's Avatar
whew! thats a relief im glad its not something broken. ill be aligning it tomorrow so it should go away. i think i need to raise it up a smig i think i went too low haha heres pics from my iphone 4 pardon my finger lol
Old 06-24-2010, 05:27 PM   #60
mws444
mws444's Avatar
Drives: 701 RWHP Lingenfelter/Pedders Beast
Looking Good, Manny!!! After you get her aligned shake her out and give us a report!
Lingenfelter forged balanced and blueprinted LS3, Maggie TVS 2300 LPE 9.5" Rearend 3.73,LPE dual disk clutch,10/14 rib belt drive,
MTI shifter,RPM Level VI,Corsa stainless cat back, Racing Brake Rotors, LPE calipers, LPE twin fuel pumps, American Racing long tube headers, GT9 cam Port and polished heads and an ADM majic tune.
701 RWHP,Fully Pedderized w/complete bushings and Sportsryder Supercar Remote resevior coilovers.
CCW 505t's Nitto Invo's and DR's
Beware of the LPE Brotherhood!
mws444 is offline   Reply With Quote
Old 06-24-2010, 05:51 PM   #61
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
Great job!. She looks great.
20 degrees or so is a lot for the Camaro and absolutely can cause the Stabilitrac light to be on. The Camaro is very sensitive to this!
You should also double check to make sure all the speed sensors are connected as well if the light does not go off.
Do you need help with the align specs?
thanks
mike
dms
Info@PeddersUSA.com is offline   Reply With Quote
Old 06-24-2010, 06:56 PM   #62
ElManny
ElManny's Avatar
thanks
mike
dms
yea they all looked good thats why i was scared cause the lights arent on at start up but once i get up to speed it comes on. i have your 2 sheets with the alignment specs i think i might go with factory specs to preserve tires since this is my DD. gonna try and lift it up a inch before alignment.
Old 06-24-2010, 06:59 PM   #63
Info@PeddersUSA.com
As a review this is what I would do for aggressive street. Since you have the Pedders adjusters installed, you will be able to do it
Front:
camber -1.0 degrees
Caster. Eccentric bolt most forward
Toe at .1 degrees toe out each wheel
Rear
camber at -.5 degrees each wheel
toe at .05 toe in each wheel
These settings will not affect tire wear and will very much improve your understeer issues.
If you want to chat about them, just call me
Hope it helps
thanks
mike
dms
Old 06-24-2010, 07:27 PM   #64
ElManny
ElManny's Avatar
Front:
camber -1.0 degrees
Rear
Hope it helps
thanks
mike
dms
what the hey they dont look that far off stock ill give those aggressive street numbers a go. i just dont have the rear alignment kit in. we chickened out dropping the craddle lol.
Old 06-24-2010, 07:52 PM   #65
Info@PeddersUSA.com
That is OK! But dropping the cradle engough to put the eccentrics in is a real peice of cake. All you have to do is drop it down about 2 inches to get the left rear toe link.
But if you do not want to do the toe link, it is really easy to do the rear camber adjuster. This is the most important one in the rear and requires no dissassembly other than removing the OE eccentric. Remember to reverse directions of the bolt, and add a little lubricant
take care!
mike
dms
Old 06-24-2010, 08:04 PM   #66
ElManny
ElManny's Avatar
take care!
mike
dms
thanks again mike im gonna see if ill have enough time to hammer it out before alignment in the am
Old 06-24-2010, 09:11 PM   #67
JusticePete
Don't forget to have the rotational rubber bushes all timed to the new ride height.
Old 06-24-2010, 10:15 PM   #68
ElManny
ElManny's Avatar
oh crap was that in the directions? if not how do i do that?
Old 06-24-2010, 10:39 PM   #69
Info@PeddersUSA.com
What you need to do is to put the vheicle in the air with the wheels loaded. Then loosen the bushings that have vertical movement, drive the Camaro 100 to 300 yards, then tighten the bushings again with the wheels loaded. This will recenter the OE bushing ferrules.
mike
dms
Old 06-24-2010, 10:52 PM   #70
ElManny
ElManny's Avatar
mike
dms
thats for all 4 wheels correct?
camaro, coil over, coilover, pedders, suspension
