03-28-2013, 10:59 AM | #1 |
Drives: 2017 Corvette Join Date: Jul 2011
Z/28 vs. C7
The Z28 is hinting around 500 hp. Some say the C7 will have 500. The Z28 is going to be about 600 pounds heavier although weights have not been confirmed. If so would have to assume 1/4 mile times much better with the C7 particularly with an automatic. Track times about the same. Most likely the C7 will be in the $50K range and with all the creature comforts. Some have hinted the Z28 will be more expensive. I personally think the C7 looks better. Unless you need four seats why would anybody buy a Z28?
03-28-2013, 11:03 AM | #2 |
¡ʇuɐıןןıɹq
Drives: 2011 Camaro IOM 2SS/RS Join Date: Dec 2010
C7, poor mans Camaro?
03-28-2013, 11:12 AM | #3 |
Drives: 21 Bronco Join Date: Jun 2012
If I was personally spending that kind of money on a car, I would rather have the Corvette.
03-28-2013, 11:33 AM | #4 |
Drives: 2013 ZL1 Join Date: Sep 2011
I started to think about getting the z28 and trading the zl1..........too close to the end of the model run........although the z28 is now likely the car to collect..I hoped the zl1 would have been but I acted in haste... ...then you still have the vette to worry about.............the move here would be to get the new vette in a couple years when they put a real motor in it.......you get your decent comfort level WITH performance and wont have anything else in your class
03-28-2013, 11:51 AM | #5 |
Only problem with that is going to be price. Most won't be able to afford that new Z07 or what ever it will be called. And too it's a long wait until it comes out if you are wanting a new car now.
03-28-2013, 12:00 PM | #6 |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
I would buy the Z/28 because it is an iconic car. I have always wanted a true Z/28 and this is a true Z/28.
03-29-2013, 07:45 AM | #7 |
Z/28 minght beat out the c7 for me purely because it is such a focused car, it is purpose built not to please a large majority, but to go fast that's it!!!
03-29-2013, 08:06 AM | #8 |
OWTATIME
Drives: 1969 CaRaMo Join Date: May 2009
I would choose the C7 in a heartbeat.
03-29-2013, 08:09 AM | #9 |
On the drag strip or road course the C7 wins hands down, the weight difference and CG difference is just too great. Folks forget the C5 Camaro is really a disguised 4 door Holden Commodore. The C6 Camaro ATS platform will be far better as it is better focused on weight as well as performance and more recent technology. What makes the C5 Camaro so popular was it's absence from 2003 to 2009 and the allowance of function follows form in the styling.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers, rotors & pads, BMR Trailing & Toe Arms, rear cradle & diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 whls, 275/40/20 & 315/35/20 tires, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console & Grant steering wheel.
03-29-2013, 08:10 AM | #10 |
Drives: 2015 Z/28 | 2017 Viper ACR Extreme Join Date: Aug 2011
First model year “base” C7 vs. ultimate Gen5 Camaro? No Contest. Z/28. There will be better Corvettes to come, as for 2014 I wouldn’t buy the C7.
dougshelbyengineering.com www.facebook.com/dougshelbyengineering www.instagram.com/dougshelbyengineering |
03-29-2013, 08:10 AM | #11 |
Drives: 13' 1LE Join Date: Apr 2012
Z28 is the better car...it has the better engine and its a pure race car!!! I dont believe the LT1 will have more than the advertise estimated 450hp.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
03-29-2013, 08:11 AM | #12 |
Drives: Camaro Join Date: Mar 2013
The new for me
03-30-2013, 08:11 PM | #13 | |
Drives: '10 Corvette GS/'13 Mustang Join Date: May 2009
I guess the Corvette is not iconic ! |
03-30-2013, 08:21 PM | #14 | |
ZL1 NIGHTMARES!!!
Drives: LACS+CHEVYS Join Date: Dec 2010
You'll just don't get it!!!
13zl1 #251 NOTHING ELSE MATTER
