Old 06-09-2013, 09:43 AM   #1
Co11in
Drives: 2013 Camaro 1LS
Vinyl wrap
Hey guys so I'm contemplating doing a solid matte black stripe on the hood and trunk along w hockey stripes on the sides I'm looking to do it my self was curious how difficult the project is?
Thanks
Co11in is offline   Reply With Quote
Old 06-09-2013, 12:37 PM   #2
black79ta
black79ta's Avatar
Drives: 79 transam with 582cid dart motor
sounds tough but if you can get the stripes layed out properly...might be okay. i assume you are doing the stickers right? if you can paint, then it is just a matter of proper layout. good luck
2010 Camaro (inferno orange, 2SS, RS and such)
cat backs, catch can, CAI on the way
79 Transam, 582 cid dart motor 779hp 315's out back 40spline gdaxles tko tranny
black79ta is offline   Reply With Quote
Old 06-09-2013, 12:46 PM   #3
cslee0811
cslee0811's Avatar
Drives: 2010 2SS/RS
Orrrrr.... you can use Finish line Vinyl Tape, lay out the design with the tape, put ur sheet of vinyl over the layout, squish it out, pull on the thread in the tape, and BAM! you have your stripes.... check it out
cslee0811 is offline   Reply With Quote
Old 06-09-2013, 11:29 PM   #4
THUMPER20X
GM fix my PAINT U suck!
THUMPER20X's Avatar
Drives: 2010 Black 1SS/RS 6Spd
This. That stuff is amazing.
THUMPER20X is offline   Reply With Quote
Old 06-09-2013, 11:35 PM   #5
TheGhosty
TheGhosty's Avatar
Drives: '11 SW 1LT RS
Just throwing this out there.. Have you considered Plasti Dip? Do a search if you haven't.
TheGhosty is offline   Reply With Quote
Old 06-09-2013, 11:54 PM   #6
AbsoluteMayheM
LongTimeLurker
AbsoluteMayheM's Avatar
Drives: 2011 SIM 2SS/RS Convertible L99
This looked like a good video for laying vinyl. The only think I would have done different was used the Finish line Vinyl Tape for the "triming" at the ends of the stripes.
2011 2SS/RS
AbsoluteMayheM is offline   Reply With Quote
Old 06-10-2013, 12:02 AM   #7
SSmokinSS
Get Some
SSmokinSS's Avatar
Drives: 2014 ZL1 6Speed
I did mine in about 2 hours.
SSmokinSS is offline   Reply With Quote
Old 06-10-2013, 07:21 AM   #8
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
you will notice that when you come to the edges of the cowl thast if you have a vinyl that has to go onto the hodd partially which most rallly stripes do it a pain in the arse......there is no taping it down its spray squueegee......use heat from blow dryer .....take back up partially...respray....squeegee....use heat squeegee more......preposition etc..............Hockey stripes should be easier, and a solid stripe ok yet still you have to work from the inside out then deal with corners..........not easy in cold ..............
christianchevell is offline   Reply With Quote
Old 06-10-2013, 10:42 AM   #9
TheGhosty
TheGhosty's Avatar
Having someone else help would make a big difference. Gives you another set of eyes to help line things up with. Try and find another member in your area who needs some beer.
