06-03-2013, 09:04 PM | #1 |
Teenage Dream Camaro
Drives: A Visually Stunning Camaro Join Date: Feb 2013
Hood is going down too deep
Ok, so I just removed the radiator shield and put it back on and not this happened, why?!?! And how can I fix this?
06-03-2013, 09:09 PM | #2 |
Stovebolt BluFlame 6
Drives: '12 2LT/RS, IBM; '20 Traverse Prem Join Date: Oct 2011
There's an adjustment for that...but I don't remember the details. It was discussed in a thread a couple months ago. Anyone out there with a better memory than mine that can provide the details or a link to the thread?
06-03-2013, 09:12 PM | #3 |
knows 2 facts about ducks
Drives: ...and they're both wrong Join Date: Aug 2009
You can adjust the bump stops (black plastic things you turn) or the hex screw that hold the radiator shroud in place. Tightening them all the way raises the bumper up, loosening them lowers it.
06-03-2013, 09:49 PM | #4 |
Thanks Stig. That was the adjustment that I was thinking of, but couldn't remember the specifics.
06-03-2013, 11:15 PM | #5 |
Thanks stig, BUT, it isn't working. Ticked. Not at you, it's just that this shouldn't happen.
06-04-2013, 07:50 AM | #6 |
If adjusting the rubber stops doesnt work, or the hex screws then raise the hood latch up, you have about 1" of play in the latch and that will raise it up. I just had to deal with this on my new hood.
06-04-2013, 05:26 PM | #7 |
Drives: 2011 2lt black Camaro Join Date: Sep 2011
did you forget to put in the cover that goes over the hood latch? Forgot what it's called
I took that off one day to wire some lights and forgot to put it back on and my hood sunk exactly like that |
06-04-2013, 05:31 PM | #8 |
Drives: 2010 Camaro LS V6 Join Date: Jul 2010
any pics of where you adjust these. mine does the same thing
C-LO or Sonic
"Without Struggle there is no progress" I am your best nightmare! |
06-04-2013, 05:43 PM | #9 |
06-05-2013, 09:19 AM | #10 |
It didn't work, Time To Take A Trip To The Dealership I suppose.
06-06-2013, 09:18 AM | #11 |
Drives: 2010 Camaro 1LS 3.6 LLT V6 325 HP Join Date: May 2009
There is two Torx screws near the latch that adjust the bumper cover if that helps.
2010 Camaro Auto, Inferno Orange, Titanium Interior, Gearhead Wheels AIRAID CAI
06-06-2013, 09:59 AM | #12 |
GAHDOOSH
Drives: 2016 Camaro 1SS Join Date: Apr 2013
Hey sorry to be the bearer of bad news, but this is the main reason Chevy is buying back my Camaro. My bumper/hood has the exact same issue, the hood is flush with the fenders, but not flush where the point of the hood its the bumper.
The issue is that the front bumper was not correctly installed, and it takes a lot of removing and adjusting to get it right. It will of course be covered by warranty, however, in my case the car was damaged before sale and the accident was not disclosed to me. My salesman and my district specialist have both been "let go" over this issue, and its been a month and I'm still waiting on a resolution. It is highly unlikely this happened in the factory, so just make sure you ask all the right questions when you go to the dealer. heres my thread http://www.camaro5.com/forums/showthread.php?t=295776
GAHDOOSH
2016 1SS 6.2L LT1 Manual 6-Speed, Front Emblem Blackout, Rear Bowtie Delete, Side emblem delete, Phastek Side Marker Tint, GM Black Taillights, $23.57 of Premium Gas this morning |
06-06-2013, 01:21 PM | #13 |
Great... Thanks for the info though
06-06-2013, 03:55 PM | #14 |
GAHDOOSH
Sorry! There are really two solutions.
The first, and easiest way, is to adjust the hood latch inside the bumper to sit up a quarter-inch higher. The second, and much more "involved" is to remove the bumper and re install it correctly. Both of these solutions can be done in a day no problem, and will certainly be covered by your bumper to bumper warranty. The real issue is that you don't know why or how the bumper ended up that way because it is highly unlikely that it happened at the factory. I would personally suggest getting to the bottom of it, and if you find that there was a repair request an extended warranty (or if you're crazy about your baby like I am demand a new car). Either way I know exactly what you're going through, I had a lot of other issues with my car as well as you can see on my thread. Keep us posted!
GAHDOOSH
