dave@hennessey
Old 03-24-2013, 03:01 PM   #1
Cuda7050
Cuda7050's Avatar
Drives: 2012 SS LS3
New SLP Style Splitter Install (cheap)
Got this splitter on EBAY for $168 plus taxes. The best part is free shipping, so about $174 total.
It came unpainted, so I used a can of matte black spray paint that matched my stripes, that came out good. The install was super easy. I drilled out the preset holes in the splitter on the bench. Used my son and wife to hold it in place along with clamps on each corner. Once held in place I drilled through the lower plastic bumper at each hole in the splitter. Even thou most install threads say you need to remove the entire front bumper I was able to simply remove two bolts under the front valance, pull it down slightly and reach up from underneath to every bolt/nut needed. Tightened each bolt (10) up with loc tight and done. Painted it Saturday, installed on Sunday (30 minutes easy).
Cuda7050 is offline   Reply With Quote
Old 03-24-2013, 03:04 PM   #2
FL1CK
Switchin' n Twitchin'
FL1CK's Avatar
Drives: 2011 Camaro
Can you link to the spiltter?
I am not childish, you're just being a poopy head!
FL1CK is offline   Reply With Quote
Old 03-24-2013, 03:05 PM   #3
2012REDSS
Drives: 2012 Camaro SS
Looks great. Modding on a budget ain't easy. Good find.
2012REDSS is offline   Reply With Quote
Old 03-24-2013, 03:17 PM   #4
Cuda7050
Cuda7050's Avatar
Drives: 2012 SS LS3
Here you go:
http://www.ebay.com/itm/181068378670...84.m1423.l2649
Goog seller for me.
Old 03-24-2013, 03:27 PM   #5
LuSe4
LuSe4's Avatar
Drives: 2013 Camaro 2SS RS LS3
wait, so this isn't the SLP splitter, just one that is styled after one? Is it hard plastic, or is it flexible?
looks really nice. Link?
-2013 Summit White over Inferno Orange 2SS RS-
-2014 White Diamond Silverado Z71 Crew Cab Short Box-
LuSe4 is offline   Reply With Quote
Old 03-24-2013, 03:46 PM   #6
JustRaf
YOU.ONLY.LIVE.ONCE
JustRaf's Avatar
Drives: Camaro 2LT/RS 2013
look sharp!I love SW.
JustRaf is offline   Reply With Quote
Old 05-25-2013, 03:20 PM   #7
Awdition
Camaro out>CTS-V coupe in
Awdition's Avatar
Drives: CTS-V
Originally Posted by Cuda7050 View Post
Hi Cuda7050 - I just ordered one of these...could you let me know what mounting hardware I need? Thanks!
CTS-V Coupe Black Diamond Edition
Awdition is offline   Reply With Quote
Old 05-25-2013, 03:43 PM   #8
HP_atTheWheels
HP_atTheWheels's Avatar
Drives: 06 Vette
How was the install? Did it come with everything needed? Might just buy myself an early father's day gift!
HP_atTheWheels is offline   Reply With Quote
Old 05-26-2013, 07:52 PM   #9
ka1
ka1's Avatar
Drives: 2011 2SS
I've been looking at these for the last couple weeks. Was just about to ask if I should get it or not. Looks like I'm doing it. The SLP one is 250 and for some reason they want $100+ for shipping!! Thanks.
ka1 is offline   Reply With Quote
Old 05-26-2013, 07:56 PM   #10
2010 SSRS
2010 SSRS's Avatar
Drives: 3 V8 Camaros
Definitely looks real good
Old 05-26-2013, 08:02 PM   #11
ROD_SS
ROD_SS's Avatar
Drives: 2013 1SS Camaro and a truck
hardware included?
ADM tuned (465 rwhp / 442 torque) Mods- CAI, kooks long tube headers, & ADM stage 2 cam
ROD_SS is offline   Reply With Quote
Old 05-26-2013, 10:19 PM   #12
chicagobulls
one car wolfpack
chicagobulls's Avatar
Drives: 2010 Camaro V6
All you need is some drywall screws no need for mounting hardware lol
chicagobulls is offline   Reply With Quote
Old 05-27-2013, 01:40 AM   #13
con10der
Con10der
con10der's Avatar
Drives: 2010 2SS/RS M6 IOM Rally Stripes
i bought the same splitter, they say its the ZL1 style. Comes without hardware. It is unpainted and rigid plastic. I used 3/8" x 2" drywall butterfly anchors. Work perfect considering the flange portion that is used for fastening is only about 4 inches deep. After taking out cheap little GM "rock" guard, we drilled (3) 7/16" dia holes (center, left, right) thru splitter, after dry fitting and marking. then drilled same in underside of bumper cover. Then fitup splitter using 3 anchors. Then drilled the remaining 9 holes directly thru splitter and bumper cover spaced appropriately. I will mention that where the splitter wraps around (90 deg bend) you can see where the anchors are installed from standing by tire and looking between tire and bumper cover flange. So instead of anchors I used 2 of the existing black plastic nut/bolt sets that the factory "rock" guard was fastened by. This way it looks like a stock install from that view. For $160, it was an easy and good looking mod that took only 45-60 minutes. Also i painted splitter with flat black to match my Rally stripes. Originally it came unpainted, sort of glossy black.
2010 2SS/RS M6 IOM w/Rally Stripes. BLK CAI w/ADM,WW Relo,2" Kooks,3" Cats-Mids,Vmax Ported TB,Muff Del,Janetty SCT Tuned,Drill/Slot BLK Hawk rotors,Red Grani Brake Lines,Motul 600,IDEAL Master w/res,Moroso CC,Accel Silver Tips w/TVolt 10.4mm,MGW shift w/Retro hand/ball,ABL Kit,Billet/IOM pedals, ZL1 split,Lloyds SS mats,PC Droid4/MAXX docking,HW Solo2.
Pend Install: Launch/Shift Light,BMR Susp/1" Drop/Sways/Track Pack,GM 3.9. Future: Janetty Pumpkin w/PosiTrac,1400HP axl,CF DS,Tick Stage 2 Trans,3 Disc Clutch,4"quad tip,center exit AB w/diff...
con10der is offline   Reply With Quote
Old 05-27-2013, 08:51 PM   #14
Awdition
Awdition's Avatar
Drives: CTS-V
Perfect! I thought Chicagobulls was joking when he said drywall screws, but in truth the butterfly anchors make perfect sense. Good call also on using the existing black nut/bolt sets at the ends.
