Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum
Old 08-20-2013, 07:02 PM   #1
ZL600 FK
ZL600 FK's Avatar
Drives: 2012 SLP ZL600 #15 (IOM) Convert
Amp for convertible
I was thinking of using the JL XD700/5 amp as it would fit in the stock location and could power a sub. What are the opinions? Will it be enough power for a sub or should I consider a separate amp for the sub?
ZL600 FK is offline   Reply With Quote
Old 08-20-2013, 07:09 PM   #2
swizlstik
swizlstik's Avatar
Drives: 2018 Garnet ZL1
I have a full JL system with the stock MyLink head unit with that same amp and two 10" subs. You are more than welcome to give it a listen sometime to form an opinion of your own.
swizlstik is offline   Reply With Quote
Old 08-20-2013, 07:33 PM   #3
ZL600 FK
ZL600 FK's Avatar
That sounds great!
Old 08-20-2013, 07:39 PM   #4
swizlstik
swizlstik's Avatar
Are you going to Augusta on Saturday?
http://www.camaro5.com/forums/showthread.php?t=314072
Old 08-20-2013, 07:57 PM   #5
ZL600 FK
ZL600 FK's Avatar
I may go, depends on weather!
Old 08-20-2013, 08:41 PM   #6
Meister
Meister's Avatar
Drives: 2016 Corvette Stingray Z51
I have installed the same amp you are considering in the factory location with a 10" Infinity sub in vert ******** box. I used the FARK and amp install plate also from ********. The amp has plenty of power for me. I have just purchased JL Audio component speakers to replace the fronts but haven't had the time to install that yet. Overall I'm a very happy with the JL amp and my setup. I also added a remote bass control switch/knob mounted near the cup holder area. That worked out good too.
Meister is offline   Reply With Quote
Old 08-20-2013, 08:51 PM   #7
swizlstik
swizlstik's Avatar
Very nice set up! I have almost the same. I put in two 10" JL subs though. It's much better than stock that's for sure!!
Old 08-20-2013, 09:01 PM   #8
Meister
Meister's Avatar
I agree. Swapping out the amp was a vast improvement alone.
Old 08-20-2013, 09:09 PM   #9
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
.get those 650’s installed!!!
Big difference.....again....LOL
Old 08-20-2013, 10:31 PM   #10
Meister
Meister's Avatar
I know. Got them this past weekend but car had to go to dealer for a little warranty paint correction Monday. I'll get it back tomorrow. Maybe this weekend - hopefully.
Old 08-21-2013, 04:26 AM   #11
ZL600 FK
ZL600 FK's Avatar
Thanks for the information guys - sounds like it will work good. Just need to get the sound system up to par!
Old 08-21-2013, 04:33 AM   #12
ZL600 FK
ZL600 FK's Avatar
Did you use the small sub box or the larger one from ********? I was hoping the small box would be enough - do not want to lose the trunk space.
Old 08-21-2013, 11:12 AM   #13
Meister
Meister's Avatar
I used the smaller one.
Old 08-21-2013, 08:13 PM   #14
ZL600 FK
ZL600 FK's Avatar
That is great as I was worried it would be too small.
