11-07-2012, 04:17 PM | #1 |
Roof expert detail noob
Drives: 2013 BRM 2LT RS Join Date: Oct 2012
Correct tire pressure
Just switched out my summer Pirellis to a set of BF Goodrich TA 245/55 R18's. I was curious what the exact tire pressure would be for these tires on my '13 RS? As of now the person whom I bought them off of had them inflated to 32psi from his '11 Camaro. Is this correct?
11-09-2012, 05:02 AM | #2 |
Wow looks like I stumped 72 people.
Here is an update to my situation. It seemed the TPS worked right after I installed the tires, but after a 15 minute drive, I received the check tire marker that was blinking, and the read out did not register the tires on the system. Is there a way to reset this as it was working when I first installed the tires and it read 32psi for each tire? |
11-09-2012, 06:07 AM | #3 |
32 to 35 sounds about right !
11-09-2012, 06:16 AM | #4 |
Drives: 45th anniversary edition v6 3.6L Join Date: Sep 2012
Yes there is a youtube and I think a thread here on how to rest your tire sensors. Also door jam has proper tire pressure. My2012 says 36 is ideal tire pressure. On cold starts ( I am in florida ) starts at33 and when they heat up run 36 maybe 37 . Hope this helps and look for that video. I just watched it few days ago. Is a setting on your radio panel and you open car door let out few pounds of air till beeps then move to next tire keeps beep and lights flash when it resets that tire
11-09-2012, 06:47 AM | #5 |
Drives: 2013 Camaro 1LT RS Join Date: Jun 2012
36 psi is correct per the sticker on my door
Loyalty above all else except honor!
11-09-2012, 09:57 AM | #6 |
Drives: 2010 Camaro SS Join Date: Nov 2008
manual states how to reset too
11-09-2012, 12:33 PM | #7 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Every car has this sticker on the door or door jam. It's 36PSI for the SS, no matter what tire manufacturer you have. Not sure what the V6 sticker says, but per the quoted poster, it's the same.
+1. It seems people forget they have a MANUAL for how things work in their car. If you lost your manual, Google has most if not all of it in some form or another. A Google search for 2010 Camaro TPS reset came up with the answer in the very first result.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
11-11-2012, 06:46 PM | #8 |
36 is the correct tire pressure, but remember I switched out my P Zero tires for a smaller BF goodrich tire, so the pressure should be less than 36.
Also for the TPMS system to read my new tires, I need to purchase a relearn tool to read the tires, or bring to a dealer for service. This I read from the manual. |
11-11-2012, 06:57 PM | #9 | |
knows 2 facts about ducks
Drives: ...and they're both wrong Join Date: Aug 2009
