Old 05-07-2023, 06:18 AM   #1
Cwilly0926
Drives: 2023 ZL1 1LE 2022 ZL1 (sold)
2023 ZLE won't stay in 3rd gear under throttle
This has happened to me 3 times now, and I only have 170 miles on my zle. Only in 3rd, if just do even medium acceleration it is popping out of 3rd and going back into neutral. Called a couple of dealers, one I saying the synchros and the other is saying 3rd gear detent. Either way the transmission will have to be opened up with less than 200 miles on the car. A real shame.
I had a 2022 base zl1 last year with no issues but I guess just got unlucky with this one.
Cwilly0926 is offline   Reply With Quote
Old 05-07-2023, 07:36 AM   #2
Vigilante375
Drives: 2018 Camaro ZL1
Probably the synchro's but won't know until they open it up.
By the way, I always take the time to say this, but there is no such thing as a base ZL1. Since the ZL1 is the only trim line for the ZL1.
The 1LE is an option not a trim. Now something like a Corvette that has the 1LT, 2LT and 3LT trims. The 1LT could be considered the base Corvette.
Old 05-07-2023, 07:48 AM   #3
LeonardS
Isn’t a ZL1 with no options, a base ZL1? That’s what I would call it.
94 Z28, Black, M6, 595 miles
69 Z28, Dusk Blue, M4
29 Ford Business Coupe
28 Ford Pickup
24 GMC Denali 2500HD CCSB 4x4
22 Jeep Grand Cherokee
13 Ford F150 Crew Cab 4x4
Old 05-07-2023, 07:48 AM   #4
dfxrte
Drives: 22 ZL1 M6
damn that's annoying. likely just unlucky but let Chevy fix it and it'll be fine
Sold: '17 m6 2SS [arctic blue]
Current: '22 m6 zl1 [vivid orange]
https://ibb.co/qpWHXZM][img]https://i.ibb.co/NKm0Q46/zl1.jpg
dfxrte is offline   Reply With Quote
Old 05-08-2023, 11:34 AM   #5
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
This is a serious problem and you should have the dealer replace the trans, do everything you can to stop them from replacing trans parts.. They will probably never get it right and it will drag on for a long time.
SFV1LE is offline   Reply With Quote
Old 05-08-2023, 11:55 AM   #6
Vigilante375
No. Base means the lowest trim of that model.
If the ZL1 had other trims, like ZL1 1LT, ZL1 2LT and ZL1 3LT then the base would be considered the ZL1 1LT.
Yes, those different version would have options that the other don't but still it doesn't count when there is only 1 trim of a specific model, like the ZL1.
Now, the Camaro SS....it has the 1SS and 2SS so the base Camaro SS would be the 1SS.
Old 05-08-2023, 12:14 PM   #7
LeonardS
We’ll agree to disagree. A ZL1 with no options will continue to be a base ZL1 to me.
28 Ford Pickup
Old 05-08-2023, 02:37 PM   #8
Cwilly0926
That is what I am hoping for, rebuilding a 300 mile transmission is not what I want nor do I have much confidence that it will be perfect afterwards.
Old 05-08-2023, 05:33 PM   #9
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Ditto LeonardS! I agree.
Old 05-08-2023, 06:38 PM   #10
Camfab
Drives: ‘23 ZL1-1LE
You sound spot on with your argument, but it’s tiring my brain and it feels way to politically correct.
I agree with the new trans, actually I’d want them to give me a new trans and I’d do the work. No dealer touching my car.
Camfab is online now   Reply With Quote
Old 05-08-2023, 06:52 PM   #11
pitrott1
OSCM(SW) USN Ret.
pitrott1's Avatar
Drives: 2023 Camaro 2SS-1LE VOM 6M
Here is what I would do first IMHO. I would put this issue to Tremec and discuss the issue and have their knowledge of the issue and any remedy/causes. It makes you look like you know the deal when talking to the Chevy service. And It may help Tremec also. My two cents worth because I would go that route.
Cheers,
OSCM (SW)
pitrott1 is offline   Reply With Quote
Old 05-08-2023, 08:58 PM   #12
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
Definitely odd. Seems like it could be shift linkage or something not torqued right and came loose. Take it to the dealer.
wakespeak is online now   Reply With Quote
Old 05-28-2023, 11:18 AM   #13
Cwilly0926
So 3rd gear synchro was the issue, parts to fix are on backorder though. My gm case manager said it will be turned over to a parts delay specialist on May 30th if still on backorder, which I'm sure they will be.
Does anyone know what the gm parts delay specialist will be doing with my case differently than my current case manager?
Old 05-28-2023, 02:03 PM   #14
taylorforschool@gmail.com
PKG4U
taylorforschool@gmail.com's Avatar
Drives: 2018 ZL1
I waited 4 1/2 months from July ish to November last year for a trans rebuild on my 10L90. My understanding is nobody particularly cares about us in this situation unless you get a truly special dealer. You are back of the line as far as service is concerned because the dealer gets paid flat rate from manufacturer for most warranty work so they can’t overcharge. They call it what they want and GM does have serious supply issues across the board for years now.
2020 Camaro LT1. Bought 10/2020 | GM PERF. CAI | GM Muffler Delete (Performance Exhaust 4” tips). | SOLD 1/2022|
2018 ZL1 Summit White | Bought 1/2022 | PDR, Recaros, Carbon Dash, WeaponX Hx System, Apex SM-10 in ZLE fitment w/PS4S
Mods after Warranty “Imma keep it stock”
taylorforschool@gmail.com is offline   Reply With Quote
