05-25-2021, 03:11 PM | #1 |
Drives: 2022 ZL1(FEA suspension) Rapid Blue Join Date: Apr 2019
DOT 4 Brake fluid
Any of you track rats switched to DOT4 fluid? Is it necessary in your opinion? Do you have problems prior and/or did you notice an increase in longevity in longer sessions?
05-25-2021, 03:49 PM | #2 |
Drives: Garnet Red / ZL1 1LE Join Date: Apr 2016
Yes, switched to Castrol SRF.
Necessary in heavy cars like ours.
#SAVETHEMANUALS
05-25-2021, 03:49 PM | #3 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
If you are tracking, it is critical that you switch. Expensive brake fluid will be the cheapest insurance you'll ever buy.
especially if you have a ZL1 1LE. Castrol SRF, Brembo HTC64T or Endless RF-650. Read the track day prep in the owner's manual.
05-25-2021, 04:00 PM | #4 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
Ditto. 100% required for track driving. Castrol SRF and Brembo HTC64T are two options I've used previously and both do well.
2017 SS 1LE.
05-25-2021, 04:03 PM | #5 |
Shadow Gray '19 ZLE M6
Castrol SRF or Motul 660 for me
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
05-25-2021, 04:10 PM | #6 |
motul 660 here
05-25-2021, 04:17 PM | #7 |
Awesome. Thanks guys. Approx quantity needed for a full flush?
05-25-2021, 04:21 PM | #8 |
1.5L but get 2L to be on the safe side.
05-25-2021, 04:26 PM | #9 |
Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
BREMBO HTC64T OR CASTROL SRF!!!! My local dealership switches mine out for me and only needs 1 Liter to make that happen. Like someone has already said.....it is the cheapest track insurance you will ever buy.
05-25-2021, 04:31 PM | #10 |
Who Needs to KNOW?
Motul BaRF (RBF?) 600 or 660
ing for grip.
05-26-2021, 09:34 AM | #11 |
2 litres of 660 on the way. Thanks all for the input!
05-26-2021, 11:41 AM | #12 |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
Motul 660 did not work for me. I had excessive reservoir "sweating" which may have been actual boil-over.
More importantly, my pedal became very spongy at times. Switching to Brembo HTC64 eliminated both spongy pedal and sweating, I know Motul makes high quality stuff but I would not use 660 again... Castrol or Brembo only IMO. |
05-26-2021, 11:48 AM | #13 |
05-26-2021, 04:28 PM | #14 |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
I use SRF as when I was asking around alot of guys had problems with Motul and almost no bad reviews for the SRF and Brembo.
