Go Back   CAMARO6 > CAMARO6.com General Forums > Z/28 Discussions
Old 03-27-2016, 09:50 PM   #1
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
N.A. Z/28 only way to go
IMO the z/28 has to stay N.A. for track use, the camaro team needs to keep the LT4 out of the track car, there way to limited for the track, they don't like heat at all, was at the race track this weekend and 3 of 3 15-16 C7 Z06 went home on a flatbed tow truck from over heating, most did not go past the 2nd set of runs, don't do this to the Z/28.
Still hoping the go with a smaller C.I. motor that pulls to 8500 RPM, that will help on Lang tracks, and get the weight down in the 3500lb range.
2SSRS@Gen5diy is offline   Reply With Quote
Old 03-27-2016, 09:54 PM   #2
Bhobbs
Bhobbs's Avatar
If the Z/28 is n/a, I bet it will be something along the lines of the LS6. Better heads, hotter cam, better intake manifold. The LS6 saw a 15% increase over the LS1. That would put the LT6 at 530 hp.
That should keep development costs down as well. Put the extra money into the light weighting. Imagine a Z/28 making 530 hp, 480 tq and weighing 3600 lbs.
Old 03-27-2016, 10:01 PM   #3
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
The Camaro platform does not seem to suffer from the issues that the Vette platform does if the media track rides of the ZL1 are any indication.
Eric SS is offline   Reply With Quote
Old 03-27-2016, 10:55 PM   #4
Tr6
The Dogfather
Drives: #1 off the line for a customer. '16
For track purposes, I would take NA over boost any day. Not due to the over heating "issues" which like Eric SS said, they did MASSIVE amounts runs without holding anything back @ track for the press and not a single overheating issues but you want NA for "instant" torque and power delivery over boost to get you out of the corners much faster. Boost will help more on straights but it's not like the car will have a 2.0 engine where it suffers on straights so with enough power, it won't be an issue and will definitely be a BEAST on track.
I do like what Bhobbs said. That would be amazing! LT has a lot more potential than the LS did, so I can even see it being 560 hp and 500 tq easy and weighing very little. Not to mention that the gen5 z28 did have a "rotofab" intake on it and not the klenex tissue panel air filter like the gen6 SS / ZL1 so they could easily start it off with the CAI one which right there is a 15+ hp to start off on top of the 455! Cams, intake manifold, heads, tri-y headers even stock with a little bit of a more aggressive factory tune, greatness can happen!
2SS, Garnet Red with Adrenalin red, NPP, MRC M6 coupe
#33 off the line #1 order for Customer.
Build thread HERE!
Story of my delivery HERE!
Tr6 is offline   Reply With Quote
Old 03-27-2016, 11:24 PM   #5
Nataphen
Drives: None
I like NA for the track too, but your comment about "instant torque" isn't an issue with a roots blower. The boost is instant, there is no lag like with turbos or centrifugal SCs.
Nataphen is offline   Reply With Quote
Old 03-28-2016, 12:34 AM   #6
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Naturally aspirated isn't the only way to go for fast track times.....but it probably is the best. Should be interesting to see how this plays out.
Old 03-28-2016, 01:40 AM   #7
Mr Monte
Mr Monte's Avatar
Drives: 2014 Chevy SS
Originally Posted by 2SSRS@Gen5diy View Post
IMO the z/28 has to stay N.A. for track use,.......Still hoping the go with a smaller C.I. motor that pulls to 8500 RPM, that will help on Lang tracks, and get the weight down in the 3500lb range.
I want to see an N.A. 5.5L in the next Z/28. Back in the day I had some playtime in a 1969 Z/28 with the crossram dual 4bl 302ci V8. What a quick reving high rpm motor.
It's nice to have options.
Mr Monte is offline   Reply With Quote
Old 03-28-2016, 02:30 AM   #8
Zeke.Malvo
Zeke.Malvo's Avatar
Drives: 1969 Mustang MaCh1
15% more power isn't always so easy. That isn't too different from LS3 to LS7 power differences, and the LS7 had some "exotic" hardware to get there. The LS7 is an expensive engine. As it is, the LT1 is an expensive engine as well relative to the LS3. To get to 15% more power while meeting emissions and MPG standards may make it as or more expensive as the LS7 is/was.
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtq
T56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear
Zeke.Malvo is offline   Reply With Quote
Old 03-28-2016, 06:17 AM   #9
Denis
Denis's Avatar
Drives: 2010 SS
I for one like the idea of an N/A Z/28. But when it comes to lag, twin scroll turbos and belt driven superchargers do a good job of mitigating that.
Denis is offline   Reply With Quote
Old 03-28-2016, 07:48 AM   #10
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
I'm curious to see what they do with it as well. There's no way it will have the problems that the C7 does. The C7 has everything stuffed into such a tight package. Even the 2014 and 2015 Z51's without a blower overheat on warm days with spirited driving on the regular road. And they're overheating in both the transmission (esp. those that got the A8) and their oil temps. I don't think the Camaro will have that problem if they add a blower...there's more room for everything to breathe.
I think the real issue with adding a blower is screwing up the weight balance. The weight of the SS is already skewed to the front of the car.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge
93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno)
LesBaer is offline   Reply With Quote
Old 03-28-2016, 09:52 AM   #11
Tr6
The Dogfather
That is a very good point! Manufacturers always love a roots system anyhow as it's so much simpler for them to put on. Just slap it on top of the engine and done.
Very true, definitely NA isn't THE only way to go. I really am curious of which way and what they will end up going with.
Build thread HERE!
Old 03-28-2016, 10:32 AM   #12
Bhobbs
Bhobbs's Avatar
The cost of the LS7 was due to the unique block and heads, along with the titanium components. The LT4 is much cheaper than the LS9, despite making more power and torque.
Building the new engine off the LT1 block and heads will help keep costs down.
Old 03-28-2016, 11:47 AM   #13
shaffe
Drives: 21 Bronco
I don't know even know if it would need that much HP. with how good the Alpha is I think 500 or a bit over would be plenty.
But I agree with you somethign ala LS1 to LS6 is what I see happening
Lets keep it simple. ..
Old 03-28-2016, 12:08 PM   #14
Bhobbs
Bhobbs's Avatar
Yeah but if 500 is good 530 is better.
