dave@hennessey
Old 09-10-2013, 08:55 PM   #1
vcyclenut
Drives: 2011 ctsv
Tire life
Obviously these tires aren't made for mileage but researching what I want to get and trying to cover all the angles of cost of ownership.
Has anyone worn out a set of stock tires yet?
If so how many miles did you get , at what mileage did the ride quality start to fall off, how aggressive do u drive.
Thanks a bunch
vcyclenut is offline   Reply With Quote
Old 09-10-2013, 10:03 PM   #2
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
5700 miles, 4 track days, 1 day at the drag strip and 100s of full throttle accelerations.
I rotated them once (dismount, remount). Outside edges of the left side are done from the track days but there is just enough rubber to make it two more months before I put the car up for the winter.
For me I figure under 7k miles and they will be replaced.
Matt
Dropspeed is offline   Reply With Quote
Old 09-10-2013, 10:25 PM   #3
Garoad Shenlong
"The Wife"
Garoad Shenlong's Avatar
Drives: 2013 2SS 1LE
6000 km (3700 miles) and mine barely look touched. I have been pretty easy on them so far though. A few spirited drives and hard accelerations but nothing major.
My girlfriend's 1LE has already gone through one set of rear tires in 16000 km (10000 miles), but the fronts are wearing excellently, think they are still at 6/32nds. She will probably go through another rear set before she has to change the fronts honestly.
Garoad Shenlong is offline   Reply With Quote
Old 09-10-2013, 11:31 PM   #4
racerx1214
Drives: 2018 SS 1LE
2800 miles, one track day and a weekend at Woodward, and my rears are done for, fronts don't look cooked yet, but lots of rubber boogers still.
racerx1214 is offline   Reply With Quote
Old 09-11-2013, 06:58 AM   #5
PYROLYSIS
Remember the Charleston 9
PYROLYSIS's Avatar
The ZL1 guys are getting 15k max out of these tires. That's only possible if you never screech a tire.
Old 09-11-2013, 07:08 AM   #6
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
Mine actually broke traction on the 1 -> 2 shift yesterday when I pulled out of a side street onto a 55mph road. It was awesome! And that was WITH traction control on.
I'm guessing I'll only get 10 to 11k out of my rears... But what the hell, I'm having loads of fun with this thing.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 09-11-2013, 07:09 AM   #7
SteveV
SteveV's Avatar
By the way, I am planning on going with the 305/35-20 when I burn up the 285s back there now... Anyone else do this on theirs?
Old 09-11-2013, 09:45 PM   #8
PYROLYSIS
PYROLYSIS's Avatar
Yes I've seen others do this. It will change the handling and give you the understeer that the engineers worked to remove out of the SS with the 1LE.
Old 09-11-2013, 10:23 PM   #9
vcyclenut
Drives: 2011 ctsv
thanks everyone for the replies
Old 09-12-2013, 12:22 AM   #10
tramtwo
tramtwo's Avatar
Drives: 2021 1LE
I am 11k and am ready for rears. The fronts still have a few thousand miles left in them. I am torn as to what my next set will be... pretty sure I will try and match the OEM square setup as much as possible.
tramtwo is offline   Reply With Quote
Old 09-12-2013, 10:30 AM   #11
jgalewsk
Drives: 2013 Summit White Camaro 2SS RS 1LE
I got Michelin Super Sports around 11k. The Goodyears in the rear were pretty much done. Mabye another 1k in them. The fronts, like tramtwo said, still had another 3-4k. No track days on the Goodyears, lots of DD miles, but a ton of full throttle accelerations...
jgalewsk is offline   Reply With Quote
Old 09-12-2013, 02:25 PM   #12
NYblack1le
Drives: 2018 1SS 1LE
18K on my goodyears and there cooked
NYblack1le is offline   Reply With Quote
Old 09-12-2013, 05:38 PM   #13
PYROLYSIS
PYROLYSIS's Avatar
You did well to get that many miles out of them. I've had people tell me that it's time for new tires when they look at them then I tell them I don't even have 2K miles on it yet. They just don't come with much tread.
Old 09-12-2013, 06:21 PM   #14
tramtwo
tramtwo's Avatar
Drives: 2021 1LE
I get that a lot... the edges make em look that way.
Sent from my DROID RAZR using Tapatalk 2
