10-17-2021, 08:23 PM | #1 |
Drives: 2012 ZL1 Join Date: Nov 2015
Are transmission problems common on these?
Heya Guys - I'm in the market for a low mileage Z28, and actually ordered one with 2K original miles from Carvana (don't judge me, single owner looked mint).
When the car arrived it kept grinding going into 1st when you were coming to a stop. I drove it around 15 mins to put some heat in it and it still kept grinding when you slowed down going to first (likely 1st gear synchronizers). I let them take it back and passed on it. I noticed when I was carfaxing a few others across the US that I'm looking at there two others had their transmissions replaced @ 5k miles and one at 7k miles. Is this a fluke or is it common to have transmission issues on these Z28s? I've had a few LSs and rebuilt a trans in my 03 Z06 (keepers got stuck) but I didn't think this tremec had any issues on these guys. Thanks, Mike |
10-17-2021, 10:29 PM | #2 |
Drives: 2015 z28 Black w/ac #645 Join Date: Jan 2017
Mine does that unless you rev match That’s normal
Edit: The Tr6060 is a damned good trans unless you you beat it hell . Sorry for being so blunt with my words LOL |
10-18-2021, 03:25 AM | #3 |
Drives: Lamborghini Murcielago Join Date: Aug 2019
I can't say I've ever had a grinding issue.
10-18-2021, 06:15 AM | #4 |
2015 Z/28 #48
Drives: 2015 Z/28 #48 Join Date: Jun 2020
No issues here at any temps..
10-18-2021, 06:34 AM | #5 |
It's not normal for a tremec to do this, your 1st gear synchronizers are likely worn and need to be replaced.
10-18-2021, 09:20 AM | #6 |
Drives: '15 Z/28 #0270 Join Date: Jan 2017
Mine has done that a few times in 5 years. Rare when it happens but it tends to grind if I put in in 1st when rolling. I learned to only put it in 1st when at a stop and lived with it. Car seems normal otherwise.
10-18-2021, 03:12 PM | #7 |
Drives: Z/28 Join Date: Jan 2015
Never experienced that
10-18-2021, 03:21 PM | #8 |
Drives: 2015 z28 Join Date: Nov 2019
Might be a dumb comment, but could the clutch fluid be low or is there somehow air in the line? Might be worth a look. This isn’t a common problem at all
10-18-2021, 04:03 PM | #9 |
This is exactly what I meant do should’ve said . My trans is fine. I should also have added that anyone’s tr6060 while rolling at a speed to fast to for your 1st gear synchro’s to catch up will grind if I’m making any sense here. Maybe I misunderstood his post.
10-18-2021, 05:33 PM | #10 |
Thanks for all of your feedback guys!
10-25-2021, 08:26 PM | #11 | |
Drives: 2015 Camaro Z/28 #968 Silver Ice M Join Date: May 2019
Good luck to Braves. Go Astros WS 2021!
Current Cars:
2008 Honda CRV 2.0L 2015 Chevy Z/28 7.0L 2016 Chevy Tahoe 5.3L Past Cars: 1976 Chevy Malibu Classic 5.7L 1985 Chevy 2DR 4x4 Blazer 5.7L 1989 Chevy IROC-Z 5.7L 1995 Chevy 2DR 4x4 Tahoe 5.7L 2005 Chevy 4DR Tahoe 5.3L |
10-26-2021, 08:15 PM | #12 |
Drives: 1969 Z/28 + 2015 Z/28 Join Date: Aug 2009
Downshift to first quite a lot and have had no real problems. Rev matching is your friend!
You know you are having fun when you are getting 3.4 mpg !!
10-29-2021, 11:32 PM | #13 |
Drives: 2015 Z/28 #898 Join Date: Oct 2016
I’ve never shifted a car into 1st before coming to a stop.
I was taught NEVER to do that and I’ve never heard of anyone doing that. Not being harsh, just giving you thoughts… As my mom taught me back in 8th grade teaching me to drive our 1980 mustang back home from baseball practice (I’m 54 now) . Coming to a stop: -Keep in any gear, let the car slow itself down in gear and push clutch in prior to stopping so she won’t stall. Shift to neutral, let clutch out (foot on brake) chill. -If you want to downshift coming to a stop, do it , but appropriate gear for speed you’re going. Maybe second gear as you’re coming to a stop(using motor to slow car down) push clutch in and follow procedure in the previous listed step. I can give you my moms number if you want. She’s still a pretty good driver at 78. She hasn’t driven my Z, but still drives my 79 Porsche 928 pretty good… Giving you a hard time.. have fun, it’s a great car!! |
10-30-2021, 12:02 AM | #14 | |
Drives: ertiga Join Date: Oct 2021
I have never faced such a type of issue. So I have just worn it, and need to be replaced as soon as possible. Regards Bhavishh |
