Vararam
Old 03-11-2024, 11:25 PM   #1
Diablo4
Drives: 2011 Chevrolet Camaro SS A/T
Question Black Spark Plugs / Stalls in a few secs
Hi guys,
In the place where I live only 87 gasoline is available, and it’s a long way to go for Midgrade and Premium. The ambient temperature during this month varies from 23F to 51F. If it’s cold, in the mornings it happens that the car starts and stalls after a few seconds (second attempt is always good). Today it happened that when I started it from the remote key, the engine stalled in 4 minutes (antifreeze 123F).
This winter I have already completely replaced the spark plugs twice. They were always found black, but not as a result of oil consumption, they were not shiny.
I own this car for 3 years and only this year started my issue with black spark plugs . In January 2023 I pulled heads and cleaned combustion chamber and valves. Also I clean injectors every 3 month.
So I have a couple of questions,
Could my problems be caused by low-quality 87 ?
Can Marvel Mystery Oil or Octane Booster solve this problem?
What could be the cause of black spark plugs? MAF sensor is good, injectors are clean.
Diablo4 is offline   Reply With Quote
Old 03-12-2024, 12:41 AM   #2
redcoats1976
izzat carbon? i dont think 87 octane is doing your engine any favors,especially if youve already had to pull the heads and clean the chambers.
redcoats1976 is offline   Reply With Quote
Old 03-12-2024, 02:24 AM   #3
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
Yeah I know it might get expensive but I would at least add an octane booster before you fill up each time because these cars weren't designed for 87 and I would change those plugs right after you use the booster and drive it for a few miles to get all that 87 out there. Now on which one to use because you don't want to go over 93. Something like this will get you to 91 with two bottles.
https://www.amazon.com/Rislone-4747-...ps%2C82&sr=8-8
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 03-12-2024, 04:59 AM   #4
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
Runs very rich.How long do you drive every day ?
chevy pilot is offline   Reply With Quote
Old 03-12-2024, 07:14 AM   #5
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
This. Octane booster is definitely needed. The engine isn’t designed for 87….
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 03-12-2024, 08:46 AM   #6
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
I'd start with checking compression and codes. Not all codes show up on the CEL. Running on a lower octane will cause the engine to knock under load which causes the ECM to lower the spark reducing power. If enough knock happens, damage occurs. It's possible the MAF sensor is dirty or having issues making the car think it's lean and adding more fuel.
FasNuf is offline   Reply With Quote
Old 03-12-2024, 11:20 AM   #7
morepowerjoe
Originally Posted by RoadRunner70 View Post
Thank you for reply and link !
Did you try Octane tablets ? I think use 2 tablets is much more cheaper than bottles ))
https://www.ebay.com/itm/175709333796
https://www.ebay.com/itm/114390590368
I haven't ever tried the tablets but I don't think thier any different.
Old 03-12-2024, 11:33 AM   #8
Diablo4
about 30 miles on highway. Yes runs very rich and I can't find the reason
Old 03-12-2024, 11:34 AM   #9
Diablo4
No, MAF is good, fuel trims are excellent, a little lean at idle.
What are the reference compression readings for L99 ? I searched everywhere and can't find anything. I checked compression before this issue 1.5 years ago. I found from 116psi to 203psi (except cylinders 6 and 8 because of bad access).
Old 03-12-2024, 11:35 AM   #10
Diablo4
Did you try Octane Booster tablets (as suggested by other member)?
Old 03-12-2024, 12:32 PM   #11
FasNuf
FasNuf's Avatar
There is no cylinder pressure spec in the SM that I see, just compression ratio.
L99 is 10.41 compression on a stock engine so I assume yours is.
Make sure all the plugs are out and the TB is wide open to allow air into the engine.
Disable the ignition system.
4 compression strokes are needed for a good test.
Minimum compression shouldnt be less than 70% of the highest reading.
Old 03-12-2024, 12:36 PM   #12
FasNuf
FasNuf's Avatar
I've seen that the atmospheric pressure x compression ratio is a good rule of thumb. so if youre around sea level that puts you around 150psi. 14.7x10.4=154.
The book did use 150psi as an example,, but not a hard spec.
Old 03-12-2024, 12:54 PM   #13
FasNuf
FasNuf's Avatar
It's just weird to me that the car stalls after warming up a little. I doubt its a compression problem,, but you said the LTFT's were good? What were they? It almost sounds like the car doesnt like going into closed loop.
Old 03-12-2024, 03:55 PM   #14
chevy pilot
What is sparkpark plug name and type ?
