02-23-2023, 07:45 PM | #1 |
Drives: 2023 Riverside Blue 2SS Join Date: Sep 2022
How much better is a SS1LE vs SS hot lapping?
I know the 1LE is extremely good around the track but exactly how much better is one vs a non 1Le? I feel like it kind of overshadowing the normal SS and no one talks about the base SS around the track.
02-23-2023, 08:30 PM | #2 |
Drives: 17 hyper blue 2SS M6 Join Date: Mar 2018
02-23-2023, 08:33 PM | #3 |
Drives: 2021 1SS 1LE Join Date: Nov 2020
We had a rental SS at Chuckwalla and my best was a 2:04 with a pasenger and not setting tire pressures...my guess that when my SS 1LE was completely stock, easily 6 seconds a lap faster....
Follow my build - https://www.camaro6.com/forums/showthread.php?t=594295
02-23-2023, 09:18 PM | #4 | |
Drives: 17' Chevy Kamaro SS 6 speed Join Date: Mar 2022
I thought all SS's came with Electronic Limited Slip Diff. |
02-24-2023, 12:16 AM | #5 |
No, the standard SS comes with a traditional (mechanical) LSD, only the 1LE comes with the electronic diff.
02-24-2023, 02:42 AM | #6 |
Drives: C8 Corvette Join Date: Mar 2013
It depends on your driving skills. For most people a regular Camaro is totally fine on a racetrack if you do racetrack trainings or stints like 1-2 times a year. But if you know what you are doing the 1LE is way more capable. The tires and suspension upgrades easily give multiple seconds advantage. But you have to ask yourself if it that actually matters.
If you drive the car daily I wouldn't want a 1LE because how hard it is dampened and how fast the expensive tires wear
02-24-2023, 08:40 AM | #7 |
Drives: 23 LT1/22 Colorado TB/69 Chevelle Join Date: Jun 2006
1LEs brakes are far superior to the standard SS for track duty. I'd recommend a brake fluid change on both models prior to track use though.
02-24-2023, 10:33 AM | #8 | |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
You could buy and install the 1LE suspension kit and 220tw tires on a regular SS and probably get close to SS 1LE lap times but the stock brakes probably would not be able to handle the usual 20+ minute sessions of fast laps found at most HPDE events without excessive front pad wear. |
02-24-2023, 10:40 AM | #9 |
And if you pay for both the GMPP 6 piston front brake upgrade and the 1LE suspension upgrade on an SS, you're probably better off just getting an SS 1LE instead at that point.
02-24-2023, 10:52 AM | #10 | |
last time i was there i did a 2:01 in my modded ss but i have a ton of mods now lol i always say if i can keep up with stock 1le guys i feel pretty good sometimes i even beat them
