Old 05-23-2022, 10:21 PM   #1
Camden45
Drives: Chevrolet Chevy
Side Skirts Required for rock protection?
Hey Guys, new member here. Search function is not working for me right now. I've been searching all around and it seems like every owner tracking their car says the side skirts are critical in protecting the rear quarter panels.
My 1LE will mainly be a street car, would I be able to get away with just the rock guards from ZL1addons? If not, is there a definitive side skirt option that's the best? ACS products seem to cost an arm and a leg, especially their rock guards. ZL1addon's skirt is cheap, and also looks the cheapest.
EOS's looks nice and a good price, but it's either CF or glossy black, which doesn't match the satin theme going on with the 1LE.
Camden45 is offline   Reply With Quote
Old 05-24-2022, 05:08 AM   #2
Nothing like an SS
Faster!!!
Nothing like an SS's Avatar
Drives: 2020 Camaro 1SS 1LE
Well, I have skirts, no rock guards, and the skirts have done wonders to protect my rear quarters. Almost 6K miles and not a chip since I put them on, not tracked, yet.....Required, not sure about that, helpful and effective? Absolutely!
I went with GM Gen II skirts, perfect fit, mounts ridiculously securely and matches the 1LE aero parts perfectly.
Nothing like an SS is offline   Reply With Quote
Old 05-24-2022, 07:00 AM   #3
Side skirts help a lot with rock chip prevention, I'd also say they do more than rock guards, but the best approach is to combine the two. I used to have RPI guards that are practically the same as ZL1 Addons, but switched to Rokblokz since then, these are wider and more sturdy.
My only regret is not getting side skirts from day 1, my rocker panels have quite a few tiny "snowflakes" in the clearcoat.
Old 05-24-2022, 07:19 AM   #4
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
The ZL1 addons rock guards aren't long enough to be effective, much. The universal mud flap is the one that works 100% of the time but you trade off that effectiveness with some style, the $15 solution is best solution.
Old 05-24-2022, 08:18 AM   #5
Hyronike
I have the side skirts but also recommend putting the 3M clear paint protection film on the front of the rear quarters. I have both and the film still has the peppered spots. when I added the side skirts I removed the film that was on the car and the paint underneath was perfect. I strongly recommend the film!!!
Hyronike is offline   Reply With Quote
Old 05-24-2022, 08:50 AM   #6
xplct
xplct's Avatar
Drives: 2022 camaro 2ss 1LE
I dont have the side skirts yet, and havent noticed anything so far at 2000 miles. Dealer added PPF on rear and door corners for me though.
xplct is offline   Reply With Quote
Old 05-24-2022, 08:52 AM   #7
ZPirate
ZPirate's Avatar
With the 1LE I recommend both rock guards and side skirts, unless you want to use PPF on most of your car. I have ACS Composite rock guards and side skirts. I like the way both fit the car.
2019 Dodge Durango R/T (daily driver)
2003 Nissan 350Z (modified)
2009 BMW 135i (Sold)
Old 05-24-2022, 10:18 AM   #8
Camden45
Thanks for everyone's responses. I did find the other threads through Google. Seems like for side skirts, the ACS ones seems to be the best option for my 1LE along with RokBlokz. Although with a side skirt, I might be able to get away with one of the sleeker rock guards. It's too bad side skirts weren't included in the price of the 1LE package, but it's still a well priced package.
Old 05-24-2022, 10:33 AM   #9
Newcastle
Drives: 2022 2 SS 1LE on order ....now a 23
I was wondering how the RokBlokz looked next to the ACS skirt. I was leaning towards all ACS but I see the value in the larger RokBlokz.
Newcastle is offline   Reply With Quote
Old 05-24-2022, 11:54 AM   #10
Wyzz Kydd
Drives: 2018 Camaro SS1 1LE
I should have purchased skirts in addition to the rock guards.
Wyzz Kydd is offline   Reply With Quote
Old 05-24-2022, 11:58 AM   #11
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i dont have any but always wanted the acs ones but heard they fall apart on track
i just stick some trackarmour on my quarter panels and it seems to work out just fine!
Old 05-24-2022, 12:31 PM   #12
Fraxum
Fraxum's Avatar
The best 2 things about side skirts are they take 10 minutes to put on. And they deflect a lot of rubber from the wheel well.
Old 05-24-2022, 06:15 PM   #13
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
C7 Designs.
Are they necessary? IDK, they are part of a good plan with the rock guards though...
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
