dave@hennessey
Old 06-07-2021, 10:20 PM   #1
1le_cam
Drives: Chevrolet Camaro
Help: Removing Caliper from Rotor without Removing Pads
I would like to swap my rotors out for a new set but I got fresh brake pads about 2,000 miles ago, so I will not be changing those. Is it possible to just remove the caliper from the rotor via unbolting it, rest it on something, and install the new rotors? Or do the pads need to be removed from the caliper before coming off the rotor. I have never done brake work before so I’m not sure if they will slide off the rotors if the pads are still inside them. Thank you in advance for the help.
1le_cam is offline   Reply With Quote
Old 06-08-2021, 05:32 AM   #2
KillboyPowerhead
Drives: 2015 Z/22
No biggie, the pads just kind of sit in the caliper - if they fall out (or you can pull them out yourself so they don't fall to the ground) just put them back in. You may need to use a clamp to push the pistons back into the caliper to make more room for the new, thicker pads.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
KillboyPowerhead is offline   Reply With Quote
Old 06-08-2021, 10:57 AM   #3
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
If they are Brembos, there is a pin holding them in. They can't even fall out. Get some bailing wire to hang them. Every time I put a block under a caliper to hold it up, I knock the block over and they end up hanging by the brake line until I get the block back under them.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
CamaroCracka is offline   Reply With Quote
Old 06-09-2021, 01:41 AM   #4
AlanRubin
Drives: 2010 LS
The pads do NOT sit in the caliper, they slide on to the bracket, then the
caliper goes on it.
Caliper is off, the bracket is where the pads go in, NOT the caliper.
This is normally how you swap the pads, remove one slide pin bolt, and flip the CALIPER up:
For ROTORS and BEARINGS:
I remove the entire loaded assembly from the knuckle, and hang it to change
rotors and wheel bearings. Remove the BRACKET bolts from the knuckle, and
take the whole thing off.
Boom, done.
AlanRubin is offline   Reply With Quote
Old 06-10-2021, 10:17 PM   #5
1le_cam
Thank you all!
brake caliper, brakes, caliper removal, rotor, rotors
