Old 07-07-2017, 12:09 PM   #1
RGV_956_Texas_Medic_272
RGV_956_Texas_Medic_272's Avatar
Drives: 2010 Red Jewel Tint LS3 Camaro SS
Unhappy Oil Leak
Good afternoon everyone, I'm looking for some help in regards to an oil leak my 2010 Camaro 2SS 6.2 LS3 is having. I have under 65,000 miles and did an oil change not too long ago and now a message comes up indicating the oil is low and to add oil. I'm just half way till my next oil change. There isn't any oil stains in my parking spot at home or at work but there is oil under the car. Also, when I drive, I've been told that smoke comes out of my exhaust when I accelerate. I'm not sure where it is coming from and was wondering if anyone else has experienced this issue. I've tried doing research and some state it could be the rear main seal or the oil pressure sensor.
RGV_956_Texas_Medic_272 is offline   Reply With Quote
Old 07-07-2017, 12:19 PM   #2
WoodBoss
"Old School"
Drives: 2010 2SS L99
Did you check the dipstick to see if is actually low?
WoodBoss is offline   Reply With Quote
Old 07-07-2017, 12:19 PM   #3
myold88
myold88's Avatar
Drives: SUMMIT WHITE 2SS/RS CAMARO
OP: The 10 SS had oil pan gasket leaks when new. Big job and mine was replaced under warranty years ago.
It sounds like you may have a more serious problem though.
Good luck getting it repaired.
myold88 is offline   Reply With Quote
Old 07-07-2017, 12:48 PM   #4
Yes WoodBoss and the dip stick indicates that it has very little oil.
Old 07-07-2017, 02:28 PM   #5
jrhagen
Drives: Camaro
Rings, valves, ????
jrhagen is offline   Reply With Quote
Old 07-07-2017, 02:40 PM   #6
RubberChicken
RubberChicken's Avatar
Drives: 2011 IBM 1LT w white Rally Stripes
Sounds like a rear main leak to me. That was a documented issue with the 2010 I believe. No pooling on the ground but a big oil stain around the leak.
RubberChicken is offline   Reply With Quote
Old 07-07-2017, 03:19 PM   #7
myold88
myold88's Avatar
Not the rear main seal. Like I said above, it was the oil pan gasket.
Old 07-07-2017, 05:16 PM   #8
I'm gonna clean the bottom of my car and add a dye to see where the leak is coming from. Hopefully it's nothing major
Old 07-07-2017, 06:37 PM   #9
Avenging Orange
Avenging Orange's Avatar
Drives: 2010 Inferno Orange 2SS/RS
Might add some oil while you are at it. Maybe check it more often. Dont want you grenading your engine.
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!!
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
KICKING CANCERS ASS SINCE 2015!!
Avenging Orange is offline   Reply With Quote
Old 07-07-2017, 06:55 PM   #10
Welker2
Ret AF, cancer survivor
Welker2's Avatar
Drives: 2013 Camaro 2SS/RS & 2006 Corvette
Check around the oil filter & make sure it sealed properly. If it didn't, it might only leak when under pressure, which would explain why you don't see any drops/spots where you park. The leaking oil will blow back under the car while your driving. Hope it's something as simple as this ... good luck
Welker2 is offline   Reply With Quote
Old 07-07-2017, 07:19 PM   #11
Thank you everyone, I will try out out your suggestions and will update you all.
Old 07-07-2017, 11:09 PM   #12
EMB135Driver
Jedi Master
EMB135Driver's Avatar
Drives: Boeing 757/767+2010 IBM 2SS
This....if it's this I hope you have extended warranty....big job
EMB135Driver is offline   Reply With Quote
Old 07-08-2017, 07:38 AM   #13
matar123
matar123's Avatar
Drives: 2012 Camaro 2SS Ls3 Cammed/Blown
It's probably the rear main seal I had the same problem and when I would accelerate the oil would spray on to the exhaust and make smoke. I replaced the rear main seal and it stopped.
matar123 is offline   Reply With Quote
Old 07-08-2017, 08:38 AM   #14
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
Also check the oil cooler which often has been abandoned and blocked off from leaking problems by some, some smoke especially modified coming on hard acceleration is to be expected going richer. Good Luck, tightening the oil pan gaskets and such is a normal maintenance issue on 50 billion old cars with cork gaskets, but your not cork. Getting underneath the car is the pain, I would spray it clean with carb cleaner and rag underneath, then later drive a little and re-inspect as it would show the area where it originates.
christianchevell is offline   Reply With Quote
#2010ls3 #oil leak
