03-16-2017, 11:54 AM | #1 | |
Drives: 16 black on black camaro rs Join Date: Mar 2017
Inexpensive Homemade tool to keep your Camaros undercarriage clean!!
Hi there, Please check out my video that will show you how to make an inexpensive undercarriage washer to keep your Camaro's undercarriage clean from all that road salt and sand! I hope you enjoy it and will try making your own at home
03-16-2017, 12:35 PM | #2 |
Drives: 2011 2SS/RS M6 Join Date: Oct 2015
Your wife is going to murder you if she finds out you used her good towels.
Good how to. |
03-16-2017, 12:42 PM | #3 |
Drives: 2013 Camaro Dusk 2SS/6 Join Date: Sep 2013
I like it! Been wanting to make one... was thinking I needed little screw in nozzles. Just drilled holes seems to work fine and saves $$$$
03-16-2017, 12:45 PM | #4 |
03-16-2017, 12:47 PM | #5 | |
thanks!! yeah def its so cheap and of course if you are able to borrow the cement and the primer from someone all u need is a little and that'll save you most of the cost. try it out and let me know how you make out |
03-16-2017, 01:09 PM | #6 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
To get even higher pressure you can tap those holes and install brass nozzles. Works really well.
03-16-2017, 01:15 PM | #7 |
good idea, I was just keeping it simple to keep the price as low as I can for the video! the pressure is pretty good with this, I tested it out in my backyard and the water was able to shoot about 15-20 feet in the air!
03-16-2017, 01:21 PM | #8 |
Lol....a sprinkler as well. I did a job at Bombadier in Quebec Canada.They build snowmobiles and atvs. We did a rinse tank for the exhaust going down a closed in conveyer systems. The piping was all PVC piping.....2 inch header with 1 inch branches. We tried what you did and were happy. Then installed the brass fittings...wow what a difference. And they are not expensive at all.....and plastic isnt hard to tap. The brass fiitings just up the pressure. Great idea you have there. I cant remember if we wven tapped it or just screwed the thread fitting in.
03-16-2017, 01:34 PM | #9 | |
cool cool definitely something to think about! |
03-16-2017, 01:41 PM | #10 | |
Inexpensive Undercarriage washer for your camaro!!
Check out my video that will show you how to make an inexpensive undercarriage washer! Hope it helps you guys keep that Camaro undercarriage clean
03-16-2017, 01:48 PM | #11 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
....rather drive over this...
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
03-16-2017, 04:03 PM | #12 |
Drives: 2013 SS Convertible, ThumperII Join Date: Nov 2016
I like it, thanks for sharing
03-16-2017, 04:34 PM | #13 |
03-16-2017, 06:13 PM | #14 |
Drives: 2010 1SS RS M6 Join Date: Jan 2015
I wonder if you squirted some soap in there before you hook up the hose if the soap would last long enough to do the undercarriage , then rinse...
Vararam intake, gmpp exhaust, borla stainless long tubes, cat less, jannetty tune, bmr lowering springs, heritage grill , smoked lenses
Tags |
car car, car care, clean, cleaning, diy, homemade, inexpensive solution, road salt, undercarriage, undercarriage washer, washer, washing |
