09-28-2014, 06:12 PM | #1 | |
Brake Failure on track w/video 2014 1le
Has anyone had trouble with what I can only discribe as COMPLETE BRAKE FAILURE. I have a video of the incident and I plan to take it to the dealer on monday but it really slowed me down the rest of the day because I couldnt trust the car.
Ill start at the beginning, I took it to the dealer and had the brake fluid evacuated and replaced 2 months ago with Castrol SRF racing brake fluid. Pads are factory but look to be in great shape the car only has 9k miles and most of that is driving back an forth to work. I have run autocross about 10 times I have tracked this car several times and learned to trust my brakes. So this thru me for a loop. Now to the Video... In the video I'm hard on the brakes at exactly 27.60 (plenty of time to slow for the corner) I hit the brakes and they were HARD AS A ROCK. The car didnt even try to stop. At Exactly 28.72 I curse and pull the E-Brake causing me to go off track and inducing a spin. (better than getting stuck in the middle of a field.) After the car restarted the brakes worked fine the rest of the day. Anyone ever have this happen? What do you think it could be? Thanks,
Drives,
2016 Camaro 2 SS, (OLD CAR)2014 Camaro 1LE, 2SS, NPP Dual Mode Exhaust, K&N Air Filter. E3 Catch Can. z28 Grill, and 1LE Badging Last edited by mcynet; 09-28-2014 at 06:24 PM. |
09-28-2014, 06:29 PM | #2 |
Remember the Charleston 9
Drives: 2004 KME PREDATOR, 2014 2SS/RS/1LE Join Date: Nov 2008
Usually when brakes fail they go soft, not hard. I find it even weirder that they worked fine after the failure. Air in the brake lines? Someone with better mechanical expertise should be able to point you in the right direction.
2002 V-6 5 speed rally red (current camaro) Also driven:1992 Z-28 305 auto Red w/ black stripes (anniversary), 2001 V-6 auto light pewter metallic,1991 RS V-6 auto Black |
09-28-2014, 06:32 PM | #3 |
Drives: 2014 Camaro 1SS/RS M6 Join Date: Dec 2011
This happens to me all the time when I accelerate fast and suddenly brake
09-28-2014, 06:33 PM | #4 |
Svt lol
Drives: 2011 ss inferno orange blown Join Date: Jan 2012
It was the key fob
plasti dip is not a mod.......and a cold air intake doesn't make you fast!
09-28-2014, 06:34 PM | #5 |
I hope you are kidding because that seems like a serious issue.
Drives,
2016 Camaro 2 SS, (OLD CAR)2014 Camaro 1LE, 2SS, NPP Dual Mode Exhaust, K&N Air Filter. E3 Catch Can. z28 Grill, and 1LE Badging |
09-28-2014, 06:37 PM | #6 |
09-28-2014, 06:37 PM | #7 |
LOL, yah when I reach down to hit the ebrake I hit the wipers... and I still missed the key fob... (Stupid Recall)
Drives,
09-28-2014, 06:40 PM | #8 | |
Have you had it looked at?
Drives,
09-28-2014, 06:47 PM | #9 |
The great ruiner of plans
Drives: 2014 Camaro 2LS Join Date: Apr 2014
That's absolutely terrifying. Even more so when it apparently "happens all the time".
Definitely get it checked out and try not to fall for any BS they might give you at the dealer. Also good on you for keeping your cool, I would've flipped out |
09-28-2014, 06:47 PM | #10 |
Not yet, it hasn't happened in a while. Mainly when the car was new (Under 10000 miles). Mine basically felt like something was under the brake pedal and wouldn't let me depress it all the way. The car would slow down, but barely, and it felt like something under the car scraped on something else. But the one time it was seriously scary was on this private road leading up to my buddy's land where I really got on it and there was a wall at the end and I braked thinking it would be normal but no, so I had to let go of the brake and pump it before it actually stopped me within a couple feet of the wall.
09-28-2014, 06:58 PM | #11 |
Drives: 2011 IOM 2SS/RS M6 Convertible Join Date: Feb 2014
Do you think you had zero braking at all, or just no power assist?
Could be a vacuum problem or a bad booster if you had some brakes just not typical power brakes. No brakes at all, and hard pedal... thats a secenario I've never encountered. Only no brake situation I've ever seen (not in a camaro) was a blown line and the pedal went to the floor with a squish and stayed there.
09-28-2014, 07:03 PM | #12 |
Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
I think you just took the corner too fast....Your speed drops significantly before you hit the dirt...My guess is your brakes are fine....
09-28-2014, 07:11 PM | #13 |
Svt lol
Honestly my guess would be the vacuum assist like cowboy said. Did it feel like you were pushing the brakes when the car is off? You know when you push down and they build pressure and get hard?
09-28-2014, 07:13 PM | #14 |
It slowed because i hit the Ebrake. thats why the wierd reaction when i hit the dirt and the rear was locked.
Drives,
