03-21-2011, 02:22 PM | #1 |
Drives: 2011 2SS/RS IOM,2000 Grand Cherokee Join Date: May 2008
Oil Dipstick In Block
So, i installed LT headers this weekend and everything went about as well as could be for a very amateur wrencher. I did have a problem at the end of my install however when i had to try to put the oil dipstick back into it's unseen hole back in the block. Does anyone have experience or info on this and how i can go about locating exactly where it has to go back in? I know you cant see it but a general location or direction on hot to get it back into it's home would help immensely.
2011 2SS/RS 6M IOM/IOM 7/23/2010 - 1100 8/18/2010 - Born on Date 2G1FT1EW1B9120590 9/3/2010 - Pick Up ----------------------------- | Photos | |
03-21-2011, 02:31 PM | #2 | |
03-21-2011, 03:15 PM | #3 | |
Slow is not an Option
Drives: 2011 2SS/RS 6M SGM Join Date: Mar 2011
try this link http://www.circletrack.com/enginetec.../photo_02.html
03-21-2011, 05:22 PM | #4 |
Drives: 2010 2SS Camaro; Join Date: Oct 2009
I took the heat shield off the starter and was able to see the hole from the top looking between the header tubes. I installed Kooks, don't know what you are running. Once you get the tube lined up, it will kinda click into place. If the bracket on the tube does not line up with the bolt hole on the cyl. head, it is not all the way in. Hope this helps.
03-22-2011, 09:46 AM | #5 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
You need to find your line of sight with a flash light before putting the header on. With the header off, you'll see the sight line is between two cylinders and looking down through the ABS pipes that are in the area. Then put the header on, and shine the flashlight down this exact same line of sight location.
If you don't find that flashlight sight line before putting the header on, it's going to be tough. If you do, it's a piece of cake using the ABS pipes and between which cylinders as sight line references. |
04-01-2011, 10:47 PM | #6 |
Camarogolfguy
You mean the car has an oil dipsitck? Shit. Tell that to my servicing dealer. He apparantly didn't know so.
04-09-2011, 02:01 AM | #7 | |
Camarogolfguy
04-11-2011, 10:51 PM | #8 |
I had some trouble doing this also. I first located it with a flashlight. Then slid it between the header tubes while I lined up the mounting bracket with the bolt hole in the cylinder head. It kind of snapped into place. I hope this helps.
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
best synthetic oil to use | hollywoodjose | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 130 | 01-26-2014 08:51 AM |
Can we use the catchcan made for the G8? | HaZe_X | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 16 | 05-05-2010 10:35 AM |
Great Read and Info on Oil Weight | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 1 | 11-23-2009 09:03 PM |
Camaro ls3 news...true or false? | Dark Knight | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 74 | 06-05-2008 05:29 PM |
Major U.S. oil source is tapped | KILLER74Z28 | Off-topic Discussions | 32 | 10-30-2007 09:47 AM |
