06-27-2017, 06:19 PM | #1 |
Drives: Camaro 2011 v6 Join Date: Jun 2017
Damaged engine
I need some answers into what I can do with my car. A mechanic told me tha one of my cylinders might be damaged because when I step on the gas it has a soft knocking and causes the car to over heat.
06-27-2017, 06:46 PM | #2 |
Drives: Camaro Join Date: Mar 2013
Trade it in, it's trashed.
06-27-2017, 08:41 PM | #3 |
Drives: 2015 Camaro LFX A6 Join Date: Nov 2015
How many miles are your car?
Cold Air Inductions CAI : Apex Air Scoop / WW Relocate Kit : JacFab Intake Manifold Spacer : Overkill 80mm Throttle Body : Overkill Tuned : MagnaFlow Cat-Back Exhaust : Elite Engineering Catch Can : ZL1 Strut Tower Brace : Custom Tunnel Brace : JPSS Caster Locks : JPSS 32mm Rear Sway Bar : JPSS Billet Radius Arm Bushings : Pegasus Solid Sub Frame Bushings : 1LE Brembo Conversion : B&M 70273 Trans Cooler
06-28-2017, 10:07 AM | #4 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Depends on condition of car. Low miles and cherry, find a replacement engine. Played out, sell it as is for someone to build a race car.
Also, the diagnosis is pretty vague. Ask specifically what repair is needed... block destroyed? Is the problem in a head? Sometimes they forget engines are repairable, it's a lost art. I bought an LS1 once at scrap price of next to nothing. All the guy said was the mechanic said it was blown up. On tear down, it had a couple bent pushrods and valves... super easy refresh, didn't even touch the short block. A good tech will tell you exactly what is wrong, and the options to repair. |
07-17-2017, 10:27 AM | #5 |
I would get a second opinion on that. You might have a batch of bad gas.
08-01-2017, 11:36 PM | #6 |
Drives: 2013 Camaro 2SS Join Date: Aug 2013
08-21-2017, 01:44 PM | #7 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Leaking head gasket maybe?
Power is worthless without control. The 2nd protects the 1st.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
