Roto-Fab
Old 06-26-2017, 09:39 AM   #1
RubberChicken
RubberChicken's Avatar
Drives: 2011 IBM 1LT w white Rally Stripes
Removal of Vinyl Stripes
I know this has probably been asked before, but I wanted to get fresh answers to this question.
What, in your experience, is the best way to remove vinyl stripes from the Camaro?
Someone in one of my earlier threads mentioned using a heat gun, but that makes me nervous as if I use too much heat I may damage the paint. Someone else mentioned using a 3M Eraser Wheel, but from what I can see that is used to clean up the adhesive once the stripe is off.
There are also some vinyl stripe remover compounds that spray on, but again I don't know how they would affect the paint.
Thanks in advance for your answers!
RubberChicken is offline   Reply With Quote
Old 06-26-2017, 10:26 AM   #2
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
Heat gun, wave it back and forth about 10 to 12" away and it will peel right off.
=Stephens= is offline   Reply With Quote
Old 06-26-2017, 11:01 AM   #3
RubberChicken
Thank you for the response!
Old 06-26-2017, 01:10 PM   #4
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
Np bro. Its easy to do.
Old 06-26-2017, 02:14 PM   #5
Syclone
Syclone's Avatar
Drives: 2015 Camaro
If there is a bit of sticky left, goo-gone works great. I deleted the rear bowtie and it cleaned it up quick and easy, paint looks great.
The early bird may get the worm, but the second mouse gets the cheese.
Syclone is offline   Reply With Quote
Old 06-26-2017, 02:22 PM   #6
RubberChicken
Thanks for the reply! I'll keep this in mind when I get to doing the job.
Old 06-26-2017, 09:56 PM   #7
Talladega
Talladega's Avatar
Drives: 2013 Camaro SS
I used a heat gun on mine, but in all honesty it took so little heat a hair dryer would likely be hot enough.
Talladega is offline   Reply With Quote
Old 06-26-2017, 10:38 PM   #8
RandRSS
RandRSS's Avatar
Drives: 2010 SS Camaro Eforce SC
I used my heat gun on #2 of 6 settings, and I actually had better success with out it on 85 degree day in the afternoon sun! Getting the glue off is the worst, if you pull straight up, near 90 to the car, it left less glue. If I pulled at a steep angle, near parallel to body, lots of glue left behind. But hey I'm an amateur what do I know! Good luck!
RandRSS is offline   Reply With Quote
Old 06-26-2017, 11:57 PM   #9
G701LE
G701LE's Avatar
Drives: 2010 2SS/RS L99 IBM silver stipes
Let it sit in the sun. Then have at it!
2010 Imperial Blue w/ Silver stripes 2SS/RS L99
Mods = Not enough....
G701LE is offline   Reply With Quote
Old 06-27-2017, 12:23 AM   #10
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Drives: 2013 ZL1 Black
Hair dryer here...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S...
Dual 10" Kicker Comp S Subs 1200w...
STUNNAH is offline   Reply With Quote
Old 06-27-2017, 06:12 AM   #11
BLU DUCE
BLU DUCE's Avatar
Drives: 2011 1SS/RS IBM Camaro
Spike III Build 2011 IBM 1SS/RS [COTW 6/25/12]
+1 Hair dryer is hot enough that is what I used on my IBM. Also if you can do it out doors in the sun where it can get get heated up by the sun. Or start up the engine to warm the hood helps.
I've done it all 3 ways.
BLU DUCE is offline   Reply With Quote
rally, removal, stripe, stripes, vinyl
