TireRack
Old 10-21-2017, 02:43 PM   #1
UF4LIFE102SS
Treasure Coast Camaro 5
UF4LIFE102SS's Avatar
Drives: 2010 2 SS
Flex fuel kit
What have people gained going 2 E85? On a cammed and boosted CAMARO?
UF4LIFE102SS is offline   Reply With Quote
Old 10-21-2017, 04:25 PM   #2
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10
Depending on your build, of course. I was able to bump boost 4psi, timing +6* and gain about 150-200rwhp over 93 octane with my SBE but "cammed and boosted" on E85 (66%).
In excess of 1,000WHP
LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is online now   Reply With Quote
Old 10-22-2017, 06:31 PM   #3
UF4LIFE102SS
Drives: 2010 2 SS
Thanks 4 the input! Maggie at 10 psi already not sure on the timing but maybe a fun thing 2 look at.
Old 10-22-2017, 07:16 PM   #4
Taylortoons
Taylortoons's Avatar
Drives: 2011 2SS/RS LS3
I am converting to E85 along with other mods, but expect the ethanol impact to be about 80 whp.
GPI Built Procharger D-1/13 PSI/Race Intercooler/SS3 Cam Kit/Kooks LTH/X- pipe/FIC 1050/E85/3.91 gears/Centerforce Dual Disc clutch/Flowmaster Outlaw/775whp/680tqSOLD
Taylortoons is offline   Reply With Quote
Old 10-22-2017, 08:10 PM   #5
cc-rider
Drives: 2010 Camaro SS
Timing does wonders to these Ls engines. Well...any engine. But it’s amazing what a few degrees of timing can do
cc-rider is offline   Reply With Quote
Old 10-22-2017, 09:31 PM   #6
Tbeanss
Drives: 2011 camaro ss
I gained 22 rwhp out of switching to e85 on my cammed car
Tbeanss is offline   Reply With Quote
Old 10-23-2017, 06:39 AM   #7
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2018 Silverado CC
I picked up about 80 whp on a 73% blend when I switched to e85.
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
760bowtie is offline   Reply With Quote
Old 10-23-2017, 09:57 AM   #8
Taylortoons
Tbean, that's one of the lowest numbers I've heard out there. Do you have a before and after dyno?
Old 10-23-2017, 10:32 AM   #9
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
It's a cammed car.... n/a. From what I've read, expect 15-20 hp on a n/a car. I'll be happy if I get 22...
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 10-23-2017, 11:36 AM   #10
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
N/a cars can pick up 10-20 hp/tq
boosted cars 50-100+
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 10-23-2017, 01:55 PM   #11
Taylortoons
Ok, 22hp on a NA car. That makes sense. This is an FI thread, so the comment threw me off.
My Procharged car is currently getting cammed and converted at the same time, so the low number was shocking. Thanks for clarifying!
Old 10-23-2017, 03:49 PM   #12
JANNETTYRACING
JANNETTYRACING's Avatar
On a recent build LS3 stock long block, SLP supercharger 2.8 pulley JRE cam LT headers JRE flex fuel conversion and JRE flex fuel tuning, made 741 RWHP 678 RWTQ on E-81.
Gains over 93 pump gas, 90 RWHP and 80 RWTQ just by switching fuel only, no tuning changes.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 10-23-2017, 04:43 PM   #13
Tbeanss
Sorry man I thought when you were saying cammed and boosted you were asking for cammed numbers and then boosted numbers.
