05-10-2010, 10:28 PM | #1 |
Drives: 2SS/RS SIM -- Lifted 99' GMC Join Date: Jan 2010
First fill up problems?
So I filled up my 2SS/RS SIM the other day for the first time!
Couple things: First, i didn't find a problem with the gas cap holder like some people have on this forum i don't see what is wrong with it i seems to work fine for me??? Second, I found myself having to hold the nozzle more upright in order for it to fill up? When I simply locked the handle in place and set it in the gas tank it kept "unclicking" I had to hold the nozzle the whole time while it was filling up which was just strange to me. Yes I know it is simple to do and doesn't take much time but I don't feel that I should be having to do it. Just set it and forget it like every other car. p.s. I've used this gas pump many times with my truck and it works fine for it but not the camaro. Has this happened to anybody else??? Thanks fellow C5 |
05-10-2010, 10:31 PM | #2 |
How U Doin?
I have the problem frequently with it wanting to click off and stop pumping. It seems as though you have to have the angel just right and I haven't experienced this problem with any other vehicle I've owned. Sometimes I'll click it in place once and that's all it takes while other times I'll have to do it 3-4 times.
05-10-2010, 10:34 PM | #3 | |
05-10-2010, 10:38 PM | #4 |
Drives: 2010 Camaro 2SS/RS - L99 - CGM Join Date: Apr 2010
The gas tank sits to high. You have to angle the handle up. Shell is the worst, but the best as far as gas goes.
05-10-2010, 10:45 PM | #5 |
Drives: 2LT RS CGM Join Date: Apr 2009
Mine works at all stations, usually, if not, and the pump is feeling extra 'flowy' that day, i put it on a slower notch. The middle usually works, but the slowest always works. The fastest works 90% of the time, so i rarely have to mess with it
05-10-2010, 10:59 PM | #6 |
Drives: 2011 LS3/RS on order... .. Join Date: Apr 2010
When I rented the 2LT, realized that the cap holder on the fuel door is NOT for the cap itself, but for the plastic cable that holds the cap. You just loop the cable over the hook... hope this helps.
05-10-2010, 10:59 PM | #7 |
Drives: 2010 2SS IOM L99 Join Date: Jan 2010
only had this problem once.all i did was put the spout further in.i use the same pump every time i get gas.i also use shell.
05-10-2010, 11:03 PM | #8 |
Drives: 2010 Camaro 2SS with RS package Join Date: May 2010
Try pushing the nozzle all the way in next time. I had the same problem and then one day i noticed that it was halfway in (like the metal part of the nozzle was still showing) so i pushed it all the way, set the clicker, and i havent had the problem anymore.
05-10-2010, 11:04 PM | #9 |
Here but not really here.
Drives: 2010 IOM Camaro 2SS/RS M6 Join Date: Sep 2009
I posted something pretty similiar in this thread about the pumping gas issue...
http://www.camaro5.com/forums/showthread.php?t=77390
05-10-2010, 11:09 PM | #10 |
Camaro SL,UTs
Drives: 2010 Camaro SS/RS #16429 Join Date: Sep 2006
Gentlemen. Just because you can shove it all the way down the hole, it's not necessary. Back off a little....
05-10-2010, 11:11 PM | #11 |
05-10-2010, 11:17 PM | #12 | |
Drives: 2010 SS Join Date: Nov 2009
As funny as that is... it's true. You gotta caress it a bit! And I never really thought of the "set it & forget it" attitude was exactly smart when dealing with something like gasoline. No complaints here.
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
1st and 2nd gear problems. 1SS 6M | jnm2003 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 7 | 10-29-2019 12:22 PM |
how often do you fill up and with what gas? | aban | 5th Gen Camaro SS LS LT General Discussions | 47 | 12-23-2011 01:25 PM |
gas fill problem | darty111 | 5th Gen Camaro SS LS LT General Discussions | 17 | 02-10-2010 11:40 AM |
V6 Oil Filter Housing - Fill w/ oil when changing oil? | bono83 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 15 | 12-06-2009 08:46 PM |
Having problems with 21's ? | Jdh02 | Wheels and Tires Talk Sponsored by The Tire Rack | 2 | 07-22-2009 05:58 PM |
