Old 06-24-2016, 06:11 PM   #1
LordKevin
Drives: 2016 Camaro 2ss Red Hot
Launch Control
So I finally figured out launch control. Turns out I just didn't have my foot down hard enough on the brake pedal. I have an automatic. It's definitely faster with launch control. My question however is the mph still goes up a little and the tires spin slightly before I actually take off. Is this suppose to happen?
How does this launch look?
https://youtu.be/2D78961xttg
LordKevin is offline   Reply With Quote
Old 06-25-2016, 08:20 PM   #2
jdasnt3
jdasnt3's Avatar
Drives: 18 Silverado 1500
It depends. I have tried it several times, and once in a while the tires give off a little chirp before settling down. It may be because I didn't have the brake pressed hard enough.
Old 08-11-2016, 07:08 PM   #3
Illmaticz
Illmaticz's Avatar
Drives: 2020 Camaro ZL1-1LE
Did you try competition mode ? I tried it a few times and I kept getting mid to high 4's the wheel spin ruins my launch all the time.
Illmaticz is offline   Reply With Quote
Old 08-12-2016, 10:15 AM   #4
JKLNHYD
Defending the Nation...
JKLNHYD's Avatar
Drives: '16 Summit White 2SS, A8, Sunroof
I can get a quicker launch finessing the skinny pedal without using launch control. In my opinion, it robs the car of a little more usable power trying to manage the wheel spin.
'16 2SS, A8, Sunroof, non-NPP
"SURSUM AB ORDINE"
JKLNHYD is offline   Reply With Quote
Old 08-12-2016, 10:24 AM   #5
HyperBlueX2
HyperBlueX2's Avatar
Convertible 2SS, A8, Track mode, TC off, Stabilitrack in competition mode, using launch control.....
Old 08-12-2016, 06:14 PM   #6
JaxChris
While driving home yesterday, I had in it track mode to listen to the exhaust and turn off the radio. At one point, I got a beep form the DIC and when I looked down it said "Performance Shifts Active" and the car wouldn't go below 3000rpm.
How did I trigger this? It felt amazing. Is there an online version of the complete operations manual to figure out all the in & outs? Being able to just reference that would be great.
Thanks.
Old 08-13-2016, 05:17 AM   #7
HyperBlueX2
Thanks.
The car senses your driving.... If you are in sport or track mode it will activate if it senses a more aggressive driving style.... every time I pass someone quickly it activates. It acts very similiar to a manual and uses engine braking and higher rpm upshifts. Hold the gears longer. Very neat feature....
Old 08-13-2016, 11:50 AM   #8
JaxChris
Would love to figure out how to activate it before leaving the line.
Old 08-13-2016, 12:51 PM   #9
Ian SS
Ian SS's Avatar
Drives: 2016 1SS, 2017 JKU Wrangler
It activates when you go full throttle. You might trigger it doing a burnout.
SLO 1SS - sold
1SS MRC NPP 6MT
2018 Ram Rebel 4x4 5.7
Ian SS is offline   Reply With Quote
Old 08-15-2016, 11:07 PM   #10
JaxChris
Tried launch control today and just stomping it in Competitive Mode.
Launch control -- repeatedly ran 4.6/4.7 with a full tank of gas and two people in the car, factory tires @ 36psi. I can see where people are saying launch control is consistent, but the driver can do better with practice (and I'm a little concerned about what this does to the factory torque converter and trans fluid/temp).
Competitive Mode -- stomping it in this mode made a very satisfying rolling burnout that didn't allow the car to go totally sideways. The car just gently swung back and forth, like a slow wag. Actually felt pretty good.
I definitely need to take the car out more nights to BFE and let the woman play spotter (in case something stupid happens in BFE, someone should be standing to make the call right?). What rpm are people manually stalling at or is 2k the limit on the A8? Is it more just about pedal position on green and gradually mashing it as you run through first gear?
Would love to learn from the guys that are already hooking up pretty well with the car.
Thanks in advance.
Old 08-23-2016, 08:03 PM   #11
RonAndersonJr
RonAndersonJr's Avatar
Drives: 2016 Camaro 2SS Black on Black
Without launch control, although I did spin the wheels.
RonAndersonJr is offline   Reply With Quote
Old 08-23-2016, 09:57 PM   #12
Slem
Slem's Avatar
Drives: 2016 Summit White 2SS (Auto) Loaded
How do you set the timer lol I have never tried this
Slem is offline   Reply With Quote
Old 08-23-2016, 11:08 PM   #13
JaxChris
When you go into the DIC configuration menu under Settings, you can enable/disable which pages you want. The 0-100mph is another page that is disabled by default.
After I finally tried launch control, I found that it produces the most consistent 4.6s 0-60mph I have ever seen (not saying much). This was two adults and a full tank of gas. I don't think dropping a person and most of the gas would get me more than 1/10th off. So I believe it when people say a driver can do better, since the factory rating is 4.0s with the A8 on an unprepped surface. Those that swap to wider wheels with stickier tires and have more seat time in their car probably can get the 3.8s that some have reported.
Old 08-24-2016, 08:36 PM   #14
RonAndersonJr
go into the performance settings with the left arrow, bottom arrow. It will read performance. Use the down arrow to move. The zero to 60/100/0-100-0/.25 mile page will say you must be stopped to use, must be stopped to use.
once you are stopped, you push select. Once you touch the accelerator the timer starts.
